Steve,
I made the bad assumption that you were installing an actual
solar power system. I suspect that the item you got was not intended to power a travel trailer. That would explain its instructions to detach loads when charging. That is probably the only way you can use that device.
We have a dedicated controller,
solar panels and gel
battery. Entirely different set up.
My mistake.
Now would you like me to also post the nasty-gram you PM'd me or is this apology enough to salve your tender male ego?
Sent from my iPhone using
Fiberglass RV
