07-02-2015, 11:15 AM
Need help designing a solar charging system
In order to accurately determine my needs for a solar system, I need to know the current draw of the appliances I use in our 13' Scamp.
Can anyone tell me the draw of these items:
Dometic RM2193 3 way refrigerator (On 12 volt, not propane, although I don't foresee actually running it on 12v)
Suburban NT-16SEQ Furnace
Bonus!
I called Fan-Tastic Vent about our model 4000R. They supplied this data on current draw:
High 3.00 amps
Med 2.20 amps
Low 1.86 amps
07-02-2015, 11:41 AM
Trailer: Class A Motorhome
Dometic RM2193 = 10 amps (actually 9.8)
NT-16 furnaces = 3.8 amps (as measured on mine)
07-02-2015, 11:45 AM
Trailer: New 1973 Compact II
You can run the device while the power is measured with a volt-ohm meter set on amps. Attach one lead to positive on device, and other lead to positive at battery source to power device. Amperage will vary as device requirements change (e.g.: low, medium, high).
07-02-2015, 12:13 PM
Louisiana
Just a quick note. Those Fantastic fan numbers can be deceiving. The fan motor may be drawing the nominal amps the company indicated, but regardless of speed, the fan will be drawing that 3 amps or so, the balance being burned up in resistance coils, ie, heat.
Many of us here have replaced the original speed control with a pulse width modulated speed control (about 6 bucks online) which controls the fan speed by rapidly turning the power on and off.
If a battery monitor is part of your solar installation, you can use the PWM controller to dial in the speed you need for comfort and see exactly the amps are being used. At night, in my small trailer, I am using about .5 amps.........no amps wasted on heat.
Clif
07-02-2015, 12:31 PM
Measuring amps
But be careful.... Most hand held multimeters are fused at 10 amps for current, some even less, and you can blow the internal fuse if you exceed that value. Much better to use a AC/DC Amp Clamp/Multimeter, Such as the Sears Craftsman 400A, one of the best electrical tools in my tool box.
07-02-2015, 07:01 PM
Bob, thanks for the information. I use the free multimeters from Harbor Freight, but when the last of them gets fried I'll opt for one like yours.
07-02-2015, 08:13 PM
Amp draw is not the only issue with solar . Charge voltages are also a consideration
My Renogy solar suitcase has a boost charge voltage level of 14.6 VDC & an equalization voltage level of 14.8 to 15.0 VDC. Both of these parameters match. up with the charge level voltages recommended by the battery manufacturer .
Unfortunately the equipment in my trailer is rated for -< 13.8 VDC .
(Fan ,LED lights ,water pump ,radio, furnace Etc.) I called the tech dept of the equipment supplers / manufacturers to verify the max voltage.
I wondered why the factory converter / battery charger on my Casita was single stage with a. maximum output of 13.8 VDC . Now I know !!
The answer I received to cure this problem was to disconnect the trailer's equipment from the bsttery when charging with solar . Makes it hard to keep the beer cold with the refrigerator off.
Some of the newer 3 stage charger / converters have the same issue.
07-02-2015, 08:30 PM
North Florida
[QUOTE=steve dunham;532618]Amp draw is not the only issue with solar . Charge voltages are also a consideration
(Fan ,LED lights ,water pump ,radio, furnace Etc.) I called the tech dept of the equipment supplers / manufacturers to verify the max voltage.[QUOTE]
I worried about this before ordering a 12V Truckfridge and contacted them concerning this. The information they provided seems to indicate their unit has a 17V limit. I don't know anything about other appliances or lights but wonder how hard the occasional over-voltage situation would be long or short term? Maybe something like an inline voltage cut-out could be used?
07-02-2015, 09:45 PM
Free....
Those free HF multimeters are worth exactly what you paid for them, both in terms of accuracy and reliability. I've tried three of them and none of them agreed with each other when reading battery voltages.
As I place a value on my time and the quality of my tools, that Craftsman meter, on it's 5th year of use, has cost less than $.05 a day, and does a whole lot things that the freebies can't do. It's a cheap investment.
07-03-2015, 05:18 PM
Trailer: Compact II
In order to actually call it a solar power system there needs to be a charge controller between the panels and the battery. These come in a multitude of complexities depending on the intended use. Solar panels may put out voltages well in excess of 13.8. The controller protects the battery and the other components from over-voltage conditions.
Without a charge controller not only will you burn out 12v toys, you won't be doing your battery any favors either!
Get an appropriate controller and enjoy cold beer anywhere!
07-03-2015, 05:51 PM
Not running in on 12V is a good thing otherwise I think you will find as many of us with solar system have that is one VERY power hunger appliance best run on propane if not plugged into power. To have enough power to run it around the clock on 12v you would need a system with 2 6v batteries, guaranteed full sun each day and enough solar panels to cover the roof of your trailer.
07-03-2015, 06:42 PM
My Renogy Solar system came with a charge controller . The controller has 4 levels of charging . The charge parameters are adjustable within limits . The. instruction booklet that
came with the controller gives a specific warning that the boost and equalization voltages provided by the controller may be harmful to connected equipment
and advises you to disconnect all loads when charging the battery,
07-04-2015, 12:01 AM
Trailer: Compact II
We lived on solar only on a sailboat for eight years. We never disconnected loads to charge. That is a totally unnecessary complication. That is what I am trying to tell you. A proper charge controller meters the voltage going into your battery. A good one even compensates for the temperature of the battery .
There are any number of good sources for information on the web or in books. This is not rocket science, but you do want to get it right.
We have two little panels, a 20 year old controller and one deep cycle group 27. We never plug in. We always have power. You can too
07-04-2015, 07:12 AM
Quote from Renogy. (Charge controller instruction manual)
" WARNING : EQUALIZATION MAY INCREASE BATTERY VOLTAGE TO A LEVEL DAMAGING TO DC LOADS .ENSURE THAT ALL LOAD ALLOWABLE IMPUT VOLTAGES ARE
GREATER THAN THE EQUALIZATION CHARGING SET POINT"
MAYBE RENOGY'S ENGINEERS ARE NOT ROCKET SCIENTIST EITHER !!
07-04-2015, 08:23 AM
Equalization voltage for 12V batteries is 15.5V. Charge controllers reduce the 17V coming from solar panel to whatever the batteries want, up to the maximum set by the operator (14.1V for gel). If a balanced system is designed, it will work.
07-04-2015, 09:04 AM
I must be missing something . My battery's manufacturerer specifies. an equalization
charge voltage of 15.0 VDC . My shurflo water pump specifies a maximum imput voltage of 13.6 VDC
When my solar charger is in the equalization mode , I have 15.0 VDC at the battery terminals and at my Shurflo pump terminals. If I leave the charger voltage setpoint at 15.0 VDC then my battery will equalize but I will be supplying an overvoltage to my pump . If I set the equalizatio voltage to 13.6 VDC then my pump is operating within its voltage limits. but my battery will not equalize. I checked the voltages with a fluke meter to verify the meter on the controller was accurate.
The advice I received from the trailer's equipment manufacturers was to disconnect the loads supplied by the battery when performing any charging operation where the charge voltage exceeds 13.6 VDC .
Disconnecting the loads will protect my equipment but will leave me without the use of my equipment during charge cycles .
How does one satisfy both criteria at the same time . I am assuming that
Renogy would not have stated their warning if the problem was non existant
07-04-2015, 09:07 AM
07-04-2015, 10:22 AM
Steve, i think i've been comparing apples and oranges, sorry. I was imagining that your charge controller had an equalization setting, specifically sending equalization voltage to the battery only, and not to the loads. As you describe the single voltage set point, it makes sense to disconnect the loads during equalization to protect them. How often is equalization necessary?
07-04-2015, 10:32 AM
Louisiana
Bonus!
High 3.00 amps
Med 2.20 amps
Low 1.86 amps
From what I can tell, this will apply to all Fantastic Vents. The difference is in the bells and whistles.
Clif
07-04-2015, 10:53 AM
The solar charge controller is factory programmed to equalize the battery every 28 days for
120 minutes. The factory boost charge level is also too high at 14.6 VDC . Again I could program the boost voltage to a lower level but the minimum setting is 14.2 VDC and by lowering the boost voltage level I increase the time frame for charging my battery.
I installed a 50 amp Anderson Powerpole connector in the line between the battery and the trailer loads/ converter so I can Isolate / disconnect during the charging cycle . I realize that I could leave the trailers equipment in the off mode ( excluding the propane detector) during charging but that method is too prone to human error IMHO. I was hoping someone had devised. a method to charge at the higher voltage levels required by the battery without endangering the trailers equipment.
Thank you for your response
