Need help finding a folding stair for Bigfoot 17 - Fiberglass RV
Old 02-23-2016, 03:42 PM   #1
Trailer: Bigfoot 17
Hello again. We have an old 1988 Bigfoot 17 that we bought fairly cheap knowing that it needed some work. My latest project is the stairs. They are bent and severely rusted. I bought a double 20" step thinking they should all be standard, but the new one is an inch too wide. My bolt holes are 18.5" wide center to center. The steps I have found online show the mounting holes at 19.25". Does anyone know the manufacturer of the old stairs such as the ones on our Bigfoot? Any help would be appreciated.
Michael Collins is offline   Reply With Quote
Old 02-23-2016, 04:59 PM   #2
cpaharley2008's Avatar
Mount them on the outside vs inside of the metal step frame....
Jim
Never in doubt, often wrong
Old 02-23-2016, 05:03 PM   #3
Have you checked out the ones they have at Vintage Trailer Supply to see if they have what you need?
Or you could try sending Bigfoot an email and ask what make/brand they used in the past. Many of the current staff worked there in the good old days but they do not have access to old files/info as to what was put on each trailer etc, but you never know they may know the answer to your question.
Old 02-23-2016, 05:59 PM   #4
Can you drill more holes in the new step or in the frame? Looking at mine , I've got lots of room for larger stairs on mine.
Old 02-23-2016, 09:58 PM   #5
Trailer: Bigfoot 17
I don't think I can. I'll take a better look at it tomorrow. The double step is too deep to mount under where the old steps were. I thought about cutting a bit of it away, and then I thought I'll just go with the single step. I looked at the specs and they aren't the same as my stock steps. The steps have an edge like an angle iron where they mount. There isn't enough area without modification to change the screw locations. I know anything is possible with a little work and ingenuity, but it might be beyond my ability. I work again tomorrow, but I'll take a pic on Thursday. Thx for the help
Old 02-23-2016, 11:00 PM   #6
tractors1's Avatar
Trailer: Escape 21 - Felicity
If you have a machine shop make up a spacer to fill in the added width they could put holes on both sides to match the mountings on the trailer on one side and the new steps on the other.
Charlie Y
Old 02-24-2016, 12:34 PM   #7
Trailer: trailswest campsterl, 1996 Scamp 16 foot
Idaho
steps
I have to agree with the solution as stated by Tractor 1. I too have a Bigfoot 17 and need to replace the steps. I purchased a double step from Camping World and am having a steel plate made that will have a hole pattern that matches the Bigfoot pattern and will also be large enough to allow additional holes that will match the steps. Lee
Lee Senn is offline   Reply With Quote
Old 02-24-2016, 01:59 PM   #8
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
On my 2002 I mounted 20" Elkhart double steps. It did take drilling an extra hole on each side of the brackets and a spacer on one side but not a major job.
Old 02-24-2016, 09:17 PM   #9
Trailer: Bigfoot 17
Thanks for the encouragement guys. I think I'm going to tackle this job. These double stairs are nice.
Old 02-25-2016, 01:24 PM   #10
Trailer: Bigfoot 17' DLX
Alaska
I'm pretty sure the OE supplier to Bigfoot for these is Elkhart Tool & Die. A lot of RV dealers sell these.
Elkhart Tool and Die : Single RV Step - RV Steps Since 1954 - Continuous Hinges - Custom Metal Fab
trainjunkie is offline   Reply With Quote
Old 02-25-2016, 02:24 PM   #11
WaltP's Avatar
SW Virginia
Yeah, they're the only 20" wide version I've found.
Elkhart Tool & Die Double Steps
Walt
Old 02-25-2016, 03:42 PM   #12
Trailer: Bigfoot 17
Thanks for those links. I do indeed have the Elkhart double step I just purchased, and my stock step is also an Elkhart single. For simplicity sake, the single would be a bolt on install. The double would be nice for our young toddler kids. Our trailer has the spring over axle conversion so it sits fairly high. I'll head outside when the kids nap today, and take a look if the double can be easily modified to work. I thought about welding a piece of flat stock steel 1.5" wide on the inside of the existing stair bolting flange. Then I would still new holes to line up to the trailer mounts. I also had interference at the top rear of the stair. Cutting 2.5" down in an L pattern would make clearance. I'll report back in a bit. Thx again.
Old 02-25-2016, 05:01 PM   #13
Trailer: Bigfoot 17
Well I crawled under the trailer today and there is no cutting involved to get double steps under the Bigfoot 17. The double steps hang an extra 2.5" lower than the single while stowed. This leaves me with 10" of clearance to the ground while trailering. This concerns me a little. I'm going to add material to one side and drill new holes to make up the extra 1.25" difference in mounting width. Would the 10" of clearance concern you guys?
Old 02-25-2016, 10:12 PM   #14
Trailer: Bigfoot 17
Thanks Lee and Walt for the idea.
bigfoot
Need help finding positive latches Angelo F. Problem Solving | Owners Helping Owners 6 02-18-2008 03:14 PM
Need Help Finding SUV to Pull My Casita Karalyn General Chat 34 11-05-2007 09:02 AM
Need Help Finding Good Battery Karalyn Problem Solving | Owners Helping Owners 10 07-28-2007 05:20 PM
Need help finding an LA campspot Linda&Dale Camping, Campout Reports 11 12-08-2006 10:02 PM
We need help finding a Microwave!!! Legacy Posts Problem Solving | Owners Helping Owners 6 02-05-2003 04:45 AM
