Need help in wiring up trailer rear lights - Page 2 - Fiberglass RV
Old 06-03-2012, 11:00 AM   #15
Trailer: Fiber Stream
no search results for "reflect-o-lite #720 /#750"
Originally Posted by Thomas G. View Post
Is there possibly a back up light also built into the light fixture?
This number is usually molded into the plastic lens, and only refers to that bit of plastic and not the fixture as a whole.
One determining factor is the color of the plastic lens:
  • Is it all RED?
  • Is it part RED and part AMBER?
  • Is it part Red and part Clear?
The other determining factor is the type of bulb each one is.
  • 2 filament bulbs have one Bright and one Dim.
  • 1 filament bulbs are either all Bright or all Dim
On my Fiber Stream I changed out the original fixtures for ones that included a Back-up light.
The model of the lens is a REFLECT-O-LITE NO 910 / 950 .
The lower bulb is an 1157; a 2 filament bulb:
  • The Bright filament is for the combined Brake/Turn Signal
  • The Dim filament is for the Running or Marker
The upper bulb is an 1156; a 1 filament bulb
  • Its Bright filament is behind the Clear section for Back-up lights
  • The amber appearance is actually RED built-in reflectors reacting to the camera flash
Name:	Tail Light Closed.jpg
ID:	47249 Click image for larger version
Name:	Tail Light Opened.jpg
If your plastic lens is all RED then the 2 filament bulb is the same as mine, one Bright and one Dim.
You need to determine what the 1 filament bulb is:
  • Is it Bright?
  • Is it Dim?
Old 06-03-2012, 11:47 AM   #16
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
Fred....where did you get your REFLECT-O-LITE NO 910 / 950 fixtures and could you measure the size....I really like the look of ours
alan H is online now   Reply With Quote
Old 06-03-2012, 11:17 PM   #17
I got them from a local RV Parts store that orders their stock from this RV On-line Catalog.
While the LENSES are Reflect-o-Lite, the COMPLETE FIXTURES are Peterson.
My Left Tail Light (with the built-in License Plate holder) is Peterson #13382.
My Right Tail Light (Plain, no plate holder) is Peterson #13412.
Lens size = 8 9/16 wide
................4 5/8 high
................1 15/16 deep
Old 06-04-2012, 01:54 PM   #18
Fred
The single fil bulb on top has to be the backup bulb. It's behind the clear lense.
The double fil are marker (on lowest lite) and brake and turn combined on the brightest.
Ron
RRJR is offline   Reply With Quote
Old 06-12-2012, 08:57 AM   #19
Smile fixed/ thanks for everyone's help
The single filament bulb on top was backup
The double filament are and brake and turn
also found a ground problem (isn't that always the problem)
Old 06-12-2012, 01:02 PM   #20
Actually - it is a completely hopeless situation - the only hope for saving your sanity is to transfer the title and give the trailer to me - since my wife says I am already nutz there is nothing to lose........
lights
Wiring problems with trailer lights Rickholt Electrical | Charging, Systems, Solar and Generators 18 07-16-2013 02:34 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
Need help on wiring new side lights, old scamp Drew Bogner Problem Solving | Owners Helping Owners 6 07-18-2006 06:44 AM
Rear Upper Shelf with LED lights. evan Modifications, Alterations and Updates 2 11-20-2005 08:04 PM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
