Need help Trillium 4500 axle - Fiberglass RV
Old 08-20-2016, 04:13 PM   #1
Trailer: One 13 ft Scamp and One 13 ft Trillium and Two Trillium 4500
Need help... Does anyone know what Dexter Axle was sued in a Trillium 4500.. Mine has some off brand axle and needs replacing.. There's a local dealer that sells Dexter axle's but said he needed to know which one.. I'm pretty sure it takes a 2500 lb axle but that's all I know, never changed out the axle before...........
Randy Bishop is offline   Reply With Quote
Old 08-20-2016, 05:03 PM   #2
Trailer: Trillium 4500
What I found:
http://www.fiberglassrv.com/forums/f...ium-27522.html
David Schroeder is offline   Reply With Quote
Old 08-20-2016, 05:38 PM   #3
Thanks David.. Now I'm more confused than ever.. Think I'll print off the entire link you posted and give that to my welder who is extending the frame and replacing the axle and let him figure it out...
Old 08-20-2016, 08:39 PM   #4
I do have a gift for confusion.
Old 09-04-2016, 08:11 PM   #5
Roy in TO's Avatar
Original specs are here:
https://trilliumrv.wordpress.com/vin...um-repair-faq/
Quoting Tom, just in case one day his site goes down.
Original Axle Specs.:
Trailing Axle w/camber
0º Starting Angle
1,500 lb. Capacity – 1300 model
2,000 lb. Capacity – 4500 model
545 Hubs
Hub Face 65″ – 1300 Model
Hub Face 66″ – 4500 Model
48″ Outside Frame Dimension – all 1300, most 4500 – Check yours
Electric Brake Backing Plate – (for 7″ or 10″ brakes)
Updated Specs – use these for replacement axles
10º Down Starting Angle
2,000 lb. Capacity – 1300 model
2,200 lb. Capacity – 4500 model – (For minimal equipment)
2,500 lb. Capacity – 4500 model – (For equipment loaded trailers)
545 Hubs
Brake Backing Plate
axle, trillium
Trillium 4500 replacement axle, specs request Tyhee Problem Solving | Owners Helping Owners 14 05-27-2015 12:59 PM
1980 Trillium 4500 16' Just purchased need help with remodel everc04 Problem Solving | Owners Helping Owners 7 06-02-2014 03:03 PM
is this axle ok? need help asap Cricket Towing, Hitching, Axles and Running Gear 29 09-23-2012 01:47 AM
Sizing New axle for '79 4500 Trillium David Schroeder Care and Feeding of Molded Fiberglass Trailers 30 05-24-2010 07:58 AM
Need help with a new Trillium 4500 project Gilles D General Chat 2 04-19-2009 08:37 PM
