Old 08-08-2012, 08:06 PM   #1
Trailer: 17' Boler
Need help with a 1979 17' Boler Water Heater
American Appliance MFG. CORP. Model No. 6 ARV
We are looking for any info, a manual would be GREAT, on the water heater.
We would like to start using it but not sure where to begin. The tank is rusted so we want to change that out but we just need to know where to begin.
I've included a picture of the label.
J W Moody is offline   Reply With Quote
Old 08-08-2012, 09:53 PM   #2
Rene's Avatar
Trailer: 1978 Boler 1700
Mine is identical and I just got it to finally stop leaking after I replaced the pressure relief valve. Had initial problems figuring out how the drain valve worked but it works ok now. I am not sure about a manual if one exists or not. Check the forums document center. You say the tank is rusted out? Does it hold water? Leaks? Besides that you need to go through the lighting procedure. If the pilot light will not stay on it may need a new thermocouple.
Rene is offline   Reply With Quote
Old 08-08-2012, 10:46 PM   #3
Trailer: Bigfoot 21
That's the unit that was in my '78 Boler 1700. When mine began to leak a bit and the pilot light wouldn't stay on, my friendly neighborhood RV fiixit shop took care of the matter by installing a whole new unit - all styrofoam encased and working like a champ!
Old 08-10-2012, 12:49 PM   #4
Trailer: 17' Boler
Thank you for the replies.
I was hoping for an exposition of parts and if the tank was easily removable.
Time to pull it out for a closer look at how rusted out the tank is and bench testing.
Everything has worked without a hiccup on this old girl so we are crossing our fingers.
Any tips, tricks or words of encouragement would be much appreciated.
Old 08-10-2012, 01:28 PM   #5
If you dont already have a hot water tank cleaning wand you should consider one. Most water tanks are designed so that they dont completely drain out and as a result with time a build up of gunk happens at the bottom of the tank. If it hasnt been used in a while I would want to make sure that all the bottom gunk is cleared out before firing it up.
As far as lighting goes I have found that my hot water tank can be a bit fussy - even though its not the original one to the trailer & less than 6 years old. It always helps to light a burner on the stove first to get the gas flowing. I often seem to have to keep the pilot button pushed on longer than one would think necessary before it will stay light.
Old 08-12-2012, 08:43 AM   #6
Trailer: 17' Boler
We have decided, due to the very rusty appearance of the tank, to not waste the time and go with the Excel LPG GAS 1.6 gpm tankless gas water heater.
Has anyone used the product and are there problems with VENTLESS type product in an RV?
Thanks again for your replies.
Old 08-12-2012, 12:07 PM   #7
You may want to do a google of the site or post under a new subject heading. This topic has been covered a few times and some members hare have used tankless heaters - I saw one being used a Bandon but it was set up outside.
Old 08-12-2012, 02:34 PM   #8
Brian B-P's Avatar
James and Wanda: please check your FiberglassRV Private Messages, and the e-mail account which you registered with FiberglassRV. There are messages waiting for you in both.
I am surprised that no one else has pointed to the manual in the Document Center which directly answers the original request, and that no one bothered to do the Google search which would have found that manual:
"American Appliance water heater site:fiberglassrv.com"
Old 10-07-2012, 07:23 AM   #9
Trailer: Boler 1700 '79
Hi there BCDave! I was wondering what unit your rv shop put in your trailer? I'm contemplating replacing mine in my '79 1700.
I'd appreciate any advice on these.
Thanks,
Graeme
Crackedegg is offline   Reply With Quote
Old 10-07-2012, 07:57 AM   #10
Trailer: 17 ft Boler
We haven't done a thing with it this year other than finding a fiberglass water tank off a boat for $10. Hubby is going to play with it in the spring. He has been to get everything else up and running including to old converter so I'm sure this will be no different. Will log progress as he goes along. Sorry I didn't have more info for you.
Wanda M. is offline   Reply With Quote
Old 10-08-2012, 12:01 AM   #11
Trailer: Bigfoot 21
Thanks,
Graeme
Sorry for the delay - have been outta town for a few days
I wish I could just say "oh yeah - its an XYZ model 123" - but I have NO idea which model or make it was - and I have since sold the trailer, so I cannot just run out to the driveway for a quick peek!
boler
Water Heater Boler 1700 Rene Care and Feeding of Molded Fiberglass Trailers 9 08-08-2011 01:46 PM
Coleman Hot Water Heater outside a Boler kevin61 Problem Solving -- Owners Helping Owners 0 07-13-2008 06:11 PM
Hot Water Heater - Rusty Water terryw Problem Solving -- Owners Helping Owners 9 07-15-2006 08:33 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
