I purchased a Fantastic Fan to install on my 16'
Scamp.
Will be putting it over the table at the back The previous owners removed a TV Ant from that location and it left a hole that has been poorly patched and will have to be fixed properly or as I am hoping to do - just make the hole bigger to fit the fan.
There is a
light in this location already - so I was going to remove it and use it's wiring for the fan. Will the wires that are there work for the fan?
What tool is best for cutting the hole in the
fiberglass with?
What size of spacer do I need to make the fan trim fit correctly. I know I can reduce the trim down to an inch but suspect that is not enough. Do I need to buy a spacer from manufacture or can I make a spacer from wood? If anyone has photo's of an install I would love to see them.
Do I need to use the foam gasket that came with the fan?
Do I use the screws that came with the fan for screwing down on the top or do I use rivets or shorter screws?
Thanks in advance for any and all suggestions.
Carol
