Need help with leak - Fiberglass RV
Old 12-29-2007, 01:35 PM   #1
Brenda Ferrell's Avatar
Trailer: 2005 19 ft Scamp 19 ft 5th Wheel Deluxe / 2006 Tundra V8
Developed a leak in the front corner of the Fantastic fan on the front
of my '05 Scamp 5r deluxe. Inside oak frame around the fan discolored
and split at the corner where the leak appears to be coming from. I
climbed up and looked at the roof. Caulking looked good without any
obvious cracks, etc. Pulled the inside frame of the fan down, but still
do not see any place it could be leaking. Any thoughts or ideas how to
proceed with identifying and fixing the leak?
Brenda Ferrell is offline   Reply With Quote
Old 12-29-2007, 02:01 PM   #2
Gina D.'s Avatar
They are hard to chase. I would pull it and reinstall with proper sealing materials (Butyl etc) anyway, even if all "looked" good.
You will have to do that anyway, even if you find it.
Replaceing the cracked part would do you good too.
Old 12-29-2007, 07:47 PM   #3
Greg A's Avatar
I thought I had a leak in the vent which started dripping from the corner similar to yours. Was condensation collecting on the inside of the vent cover.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 12-31-2007, 06:47 AM   #4
Thanks Gina and Greg for your replies. I'm hoping it is condensation as this will be an easy fix (open window) as opposed to pulling the fan. I recaulked a couple of the screw heads and will see what happens. Thanks again.
Old 12-31-2007, 01:46 PM   #5
Trailer: Casita Spirit Deluxe 17 ft
Brenda, I had a leak in the same area as yourself and tried a number of fixes without success over a period of several months and with much frustration. I finally determined the leak or water was entering around the hinge area of the Fantastic fan. I contacted the company (they are very responsive) and they said it is very possible to have a leak where the hinge assembly is joined with the frame. They offered to completely recondition and return postpaid (even though the unit was over three years old) if I would remove and ship the fan to them. I ultimately decide to install one of the after-market fan covers that mounts over the fan. This completely shields the hinge and the problem was resolved. Cost of cover was about $30.00-- easier than removal and reinstall. I doubt very much your leak is condensation. Martin
Martin D is offline   Reply With Quote
Old 01-01-2008, 09:49 AM   #6
Thanks Martin. I have cosidered this as I had a MaxxAir cover on my Casita and loved it. I installed it myself and thought it was an easy job, even for a novice "Modder" as I consider myself. I'm still in the "see if this works" stage, but the cover is #1 on my list if all else fails.
Old 01-01-2008, 10:39 AM   #7
If the problem is truly the hinge, then the MaxxAir cover is a simple solution. However, if you're not absolutely certain that's where the leak is coming from... then the cover may force the water into a different area with a different flow path and you might not find the area leaking for many moons... like until the floor gets spongy in a corner. You're always far better off tracking down the leak than trying to disguise it. Perhaps the inconvenience and time spent now will prevent a bigger inconvenience, time and DOLLARS spent later
Old 01-01-2008, 05:20 PM   #8
I agree with Donna - it is important to find the actual leak point. I would mask off the entire vent assy where it is sealed to the roof. I would then take a large cooking baster or syringe and carefully apply water to the hinge area and determine if water appears inside after a period of time. If the inside trim or frame can be easily removed it will enhance finding the water entry point. Martin
Leak? cyndi H Problem Solving | Owners Helping Owners 5 11-09-2009 01:07 AM
GAS LEAK Keith & Beverly General Chat 3 09-01-2009 02:57 PM
Leak! Help! BOBSMITH Problem Solving | Owners Helping Owners 7 10-02-2008 11:38 PM
A/C leak? Linda R002 Problem Solving | Owners Helping Owners 7 03-11-2007 04:50 PM
Leak Legacy Posts Problem Solving | Owners Helping Owners 5 06-27-2003 03:14 PM
