Need info on adhesive for rat fur - Fiberglass RV
Old 08-06-2019, 03:11 PM   #1
Massachusetts
Anyone know what is the recommended type of adhesive to use when reattaching the rat fur strips on the Scamp.
I want to run some new wires behind the rat fur and might have to peel away a small section on rat fur where it is seamed to do so. Wiring in a third tail/stop/turn signal led assembly above outside window and will have to snake wire form above center of back window down one of the walls to make up wiring connections.<_< Figured it might be easiest to use the areas where the seams are.
Thanks,
Jack
Lockman is online now   Reply With Quote
Old 08-06-2019, 04:05 PM   #2
Thanks,
Jack
You have a phone right? Call Scamp.
Old 08-07-2019, 12:16 PM   #3
Trailer: 96 Casita Spirit Delux 16 ft
Utah
I've only had to run one wire behind the rat fur on my Casita and that was in the ceiling. I found an old CB antenna that was stiff but flexable enough to follow the curvature of the shell. It worked well and I can't even see the path of the wire behind the material. If one can avoid removing the rat fur it would save lots of work. Worked for me.
Doninut
Doninut is offline   Reply With Quote
Old 08-07-2019, 12:19 PM   #4
Doninut
Casita doen't use "rat fur" for wall coverings.
Old 08-07-2019, 12:27 PM   #5
No, but the technique Don describes can work for short runs under rat fur, too.
Old 08-07-2019, 01:49 PM   #6
IllAnnoy
You can use an old school coat hanger for a needle.
I use a length #9 stainless wire, slightly sharpened on on end and looped on the other for a needle eye. strip the wire back about an inch and attach it to the eye. You can bend the "needle" to conform to shape as you guide it.
Works great!
If you are going to install double cord wire, shorten one side a bit for a better install .
Add a little electrical tape to secure the wire to the needle.
Old 08-07-2019, 02:52 PM   #7
Massachusetts
Thanks for your informative reply's, still looking for some adhesive. Am waiting for a reply from Scamp.
Jack
Old 08-07-2019, 04:21 PM   #8
IllAnnoy
Jack
3M "77" or "90"... depending on the job size and application.
I think the 77 is better for small jobs or touch up.
The 90 I believe is what Scamp uses for overall construction (or it is very similar)
I use the 08090 around the shop for automotive applications.
Old 08-07-2019, 06:23 PM   #9
Trailer: 2014 Escape 21, Lil Joe
Hot glue
Hot glue works great for re attaching the rat fur trim strips. The 3M-90 seems to work better than the 3M-77 and holds up better under heat.
Eddie
Eddie Longest is online now   Reply With Quote
Old 08-07-2019, 09:13 PM   #10
Massachusetts
Many thanks Floyd & Eddie for the info.
Jack
Old 08-14-2019, 09:45 PM   #11
Kansas
3M 90
We replaced all the insulation and rat fur on our Scamp 16, 100% replacement, using 3M 90. Good as new, works great.
Doc.Kev is offline   Reply With Quote
Old 08-15-2019, 08:56 AM   #12
Massachusetts
Thanks Kev.
It looks like you and Floyd both agree on that, good to know. I'll go with the 3M 90.
Jack
Dead Rat Fur need help RV NUT CASE Problem Solving | Owners Helping Owners 53 09-23-2018 02:21 PM
Adding Rat fur in my remodel job. ( Need help ) Monte W General Chat 8 10-29-2017 02:13 PM
Scamper friends: I need a little rat fur k0wtz General Chat 16 10-18-2017 06:33 PM
Replacing Rat Fur peterh Care and Feeding of Molded Fiberglass Trailers 4 10-20-2006 11:50 AM
RAT FUR..CAT DOESN'T UNDERSTAND Susan Tiller General Chat 12 04-23-2006 10:12 PM
