Need some ideas on rot repair under water tank - Fiberglass RV
Old 10-30-2015, 03:39 PM   #1
Ohio
I have some ideas but would love someones input that has done it successfully
Thanks in dvance
cmartin748 is offline   Reply With Quote
Old 10-30-2015, 05:06 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Can't really see anything with the tiny thumbnail pictures............
Charlie Y
Old 10-31-2015, 05:57 PM   #3
Roy in TO's Avatar
Depending on the age of your trailer and other things, I think you have 3 basic options.
  1. Git Rot the area
  2. Cut out and glass in a patch of the bad section
  3. Replace the floor in that section of the trailer.
All 3 have been done with many pictures posted here in the forums.
Old 11-01-2015, 11:50 AM   #4
You will want to investigate the extent but also the source of the rot. In the case of my Trillium, there was some rot but only immediately around the screw holes for the straps that held down the tank. Easy fix. Had it been more expensive I'd have replaced the plywood in the area affected and recoated it with resin. It's important to keep this area of the floor strong because in my case the bolts that hold the body to the frame pass through it.
Randy J. is offline   Reply With Quote
Old 11-03-2015, 05:55 PM   #5
Ohio
Thanks folks! repairs are underway. I fixed the long ago. It was a rivet on the roof that gave me a fit to find. I found a piece of laminated oak that is actually lighter than the 3/4 OSB for the repair.
Grey Water Tank Ideas...Collapsible? Zennifer Problem Solving | Owners Helping Owners 10 08-19-2015 08:42 PM
any ideas for adding some storage space under a trailer alan H Modifications, Alterations and Updates 6 08-16-2014 07:05 PM
rot repair.... jordan Hi, I am.... 1 08-21-2013 06:18 PM
Bad threads on the water tank. Ideas? Raz Problem Solving | Owners Helping Owners 28 04-27-2012 09:10 PM
Larger Fresh water Tank Ideas Steve Rosenberg Plumbing | Systems and Fixtures 8 12-15-2007 07:36 AM
