Need your cabinet door ideas/mods - Fiberglass RV
Old 09-19-2009, 03:03 PM   #1
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2004 Element
I want to make my Perris Pacer as lean as possible for towing. Would like to start with maybe replacing the storage doors. I've tried to read all the posts I can find on here. But have a feeling I've missed some.
What did you replace your doors with? Pictures would be great. I'm especially open to fabric ideas. Someone on here mentioned a stiff fabric connected with velcro on the four corners.
Right now the fabric store has vinyl on sale. This is a durable, easily cleaned, no hemming needed, possibility. Many colors. What do you think? I've had good luck with industrial velcro on other projects---how do you think it would work for this???
Another person on here mentioned wedging cutting boards, collapsible strainer, etc in the openings while moving to prevent things falling out. I even thought about cutting pieces of foam core board that would fit in the openings while in route, then taking them out when settled. (Thus giving the fabric some help during transport.) Don't want to overthink this, tho.
So far we've removed the bunk hardware: piano hinge/side rail/ legs. Some of those items were heavy! Also, the sink came with a HEAVY metal lid---I mean heavy! Would like to replace it with the cutting board with side handles I saw in someone's pic (they got it at Dollar Store!) but can't find the darn things now! It fit so nicely in the photo.
Has anyone ever replaced the metal table support with PVC pipe? Most of the time, our dinette will be a bed anyway.
ANY ideas you have will be appreciated!
1988 Perris Pacer
2010 Honda Ridgeline
2013 Winnebago Minnie 2101FBS
Vickie B. is offline   Reply With Quote
Old 09-19-2009, 03:24 PM   #2
Thumbs up
I'm especially open to fabric ideas. Someone on here mentioned a stiff fabric connected with [b]velcro on the four corners.
How about Upholstery Snaps?
Old 09-19-2009, 03:28 PM   #3
pjanits's Avatar
Trailer: 17 ft 1986 Burro
On my old Burro I used clear pine shelving cut to size and given three coats of poly for all the doors. Pretty matching grain and looks like Ikea. Pine is very light so it will dent easily. I made the dinette table from the same shelving. I comes in different widths from Menards.
The bed I made permanent with 3/4 plywood, which was still lighter than the presswood stuff they had.
On the new ( to me ) Burro I'm still deciding whether to go with the clear pine again or birch plywood.
The plus on the pine is no banding needed on the sides.
Old 09-19-2009, 03:47 PM   #4
Oliver manufacturer uses smoked plexiglass... or you could use colored plexiglass. Just another idea.
Old 09-19-2009, 04:12 PM   #5
1/4" oak plywood with slightly rounded corners is probably nearly as light as some fabrics and it looks great and is more secure.
OR...
How about the above idea, only cut the door out of luan, then cut the center out leaving an inch or inch and a half frame of luan, then staple fabric or rollex aluminum or even screen wire on the backside. this would make a strong and servicable door that would weigh almost nothing!
OR...
How about a canvas fabric with a hem top&bottom, then use stainless wire to run through the hem , which would allow it to slide left and right to open and shut.
OR...
How about the clips used on above ground pools to hold the liner in!! They would hold your fabric firmly and give it a finished look . They are easily cut to length. They are dirt cheap, and weigh almost nothing. Use a long piece on one side like a hinge then use another with part of the back side removed for the side you want to open and shut. If needed a very small round headed screw could be used along with a small hole in the clip to act as a snap latch.
Old 09-19-2009, 04:20 PM   #6
Gina D.'s Avatar
Birch plywood is also light as a feather. It can be had at Lowes with a veneer on it, in 2ft x 4 ft sections. Cut, trim, finish, hang.
Old 09-19-2009, 08:40 PM   #7
Vickie B.'s Avatar
Great ideas! Many thanks
1988 Perris Pacer
Old 09-19-2009, 09:45 PM   #8
Roger C H's Avatar
Talking
I'm thinking along the lines of sliding doors. Wood tracks top and bottom, (parting stop or molding with saw kerf?), and acrylic, plexiglass, or aluminum sliding doors. Advantage: door doesn't open in direction contents would load it. Disadvantage: finding room for door to clear opening. Magnetic latches?
Old 09-20-2009, 12:48 PM   #9
Tom U's Avatar
Trailer: Fiber Stream 16 ft
We are replacing the upper cabinet doors (hinged) with sliders made of 1/8" acrylic. We are using black, white and different colors. for two part doors there is plastic track available. I made three runner track for the longer cupboards. The track acts as a fiddle and keeps things inside.
While in motion we will be securing the doors with foam wedges.
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 09-20-2009, 03:24 PM   #10
Talking
That's what my 1978 Fiber Stream has, (with plastic tracks) and they are factory original. A previous owner added Velcro tabs to hold them closed while in transit.
Old 09-20-2009, 05:06 PM   #11
peterh's Avatar
I made our cabinet doors from 1/4" poplar and 1/4" birch plywood with a lightweight inset. (Our inset is a lightweight punched aluminum panel we got at Lowes, but you could use almost anything. Bamboo placemats to a piece of Plexiglas with a photo behind it.) It's a fraction of the weight of the MDF fiberboard doors our Scamp came with.
Old 09-20-2009, 05:29 PM   #12
Vickie B.'s Avatar
You guys are so smart! Thanks for pics---I'm a very visual/tactile person.
1988 Perris Pacer
Old 09-21-2009, 08:39 AM   #13
Tom U's Avatar
[quote]I made our cabinet doors from 1/4" poplar and 1/4" birch plywood with a lightweight inset. (Our inset is a lightweight punched aluminum panel we got at Lowes, but you could use almost anything. Bamboo placemats to a piece of Plexiglas with a photo behind it.) It's a fraction of the weight of the MDF fiberboard doors our Scamp came with.
Attachment 23597
Great look and good drawings! Thanks.
Cabinet Door Latches CliveAlive Problem Solving | Owners Helping Owners 8 01-25-2010 08:20 PM
2001 Scamp Cabinet Mods Matt Brown Modifications, Alterations and Updates 8 04-27-2009 11:57 PM
Cabinet door latches Ian R Modifications, Alterations and Updates 7 05-23-2007 10:35 AM
cabinet doors any ideas? david john Modifications, Alterations and Updates 3 02-16-2007 07:16 AM
Cabinet door material Isaac M Problem Solving | Owners Helping Owners 6 06-30-2006 03:01 PM
