New battery...no lights... - Fiberglass RV
Old 07-04-2013, 03:58 PM   #1
Newfoundland
Just bought a new 12 v battery for our new-to-us 1980 Boler. All the lights work when plugged in to the house but nada with the new fully charged battery.
Any suggestions for what to check next appreciated.
Pegnorman is offline   Reply With Quote
Old 07-04-2013, 05:55 PM   #2
Roy in TO's Avatar
See if your converter has a switch to switch over to 12V.
Old 07-04-2013, 07:13 PM   #3
Look for a fuse between the battery and the converter. Some units even have 2 fuses.
Old 07-04-2013, 08:02 PM   #4
Newfoundland
No fuses
Looked for a fuse- none. Two reset breaker buttons. Pushed both, nada.
Here's a photo of the converter.
Old 07-04-2013, 08:26 PM   #5
Trailer: '77 Scamp
Make sure your positive and negative wires are not crossed at the battery connection. The trailer wires are often not the colors you'd expect.
Otters is offline   Reply With Quote
Old 07-04-2013, 09:44 PM   #6
Brian B-P's Avatar
The converter may be the same as mine, described in Electrical Problems 1979 Beachcomber (post #6).
This converter disconnects the battery with a relay when plugged in, and I found that sometimes the relay sticks and fails to reconnect the battery when unplugged from the outside power. I only had to bang the front panel to unstick it.
Old 07-05-2013, 06:07 AM   #7
pugslyyy's Avatar
might be time to invest in a multimeter if you don't have one!
pugslyyy is online now   Reply With Quote
Old 07-05-2013, 06:18 AM   #8
ShawnKK's Avatar
May I ask what size Boler? Love to see some pics of it and if you did any mods.
ShawnKK is offline   Reply With Quote
Old 07-08-2013, 03:15 PM   #9
Newfoundland
It's a 1980 FG16. On the road with it now. Have to say, it's a lot more fun than our 13 footer.
Old 07-08-2013, 03:26 PM   #10
ShawnKK's Avatar
Looks good Peg. But why did you touch me and walk away? I want to see the inside too.
Old 07-08-2013, 04:53 PM   #11
Brian B-P's Avatar
Thanks for the converter photo. It's not the same as mine, and probably not a Powertron, but it might still work the same way. I can't make out the brand and model information on the top - can you read it, or get a more detailed photo of the label?
lights
Flickering lights on 110 Not battery arashaw Electrical | Charging, Systems, Solar and Generators 19 03-29-2013 03:38 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Help dead battery & still no lights plugged in- Mark J Problem Solving | Owners Helping Owners 8 12-09-2009 04:15 AM
DC lights working with no battery connected???? dora D Problem Solving | Owners Helping Owners 4 10-10-2007 06:17 PM
Sylvania Dot-It; stickble battery-powered LED lights Laura Heiman Modifications, Alterations and Updates 2 04-12-2006 01:15 PM
» Trailer Showcase
Scampooh
Kkightly
Alice
Mr.Stu
