New boler frame help - Fiberglass RV
Old 08-15-2015, 08:17 PM   #1
sir
Hi,
I just had a new frame made for my 1975 13' boler. I put it under the shell and the shell doesn't sit on the frame everywhere.
It sits on the front and rear but some places in the middle are still up to an inch or two away. Especially where the old frame was broken behind the left wheel.The new frame is straight. Just wondering if there is a trick to getting the shell to settle on the new frame? Any help is greatly appreciated. Thanks
Saul
sir is offline   Reply With Quote
Old 08-16-2015, 10:17 AM   #2
Keaner's Avatar
Trailer: 1973 13' Boler
Do you have your old frame to compare measurements?
Keaner is offline   Reply With Quote
Old 08-16-2015, 10:35 AM   #3
bullfrogeh's Avatar
Hi Saul; - welcome to the FHRV forums. I am in a similar stage as you seem to be. I am presently working on a frame-off restoration of my 1973 Boler; removed shell, had existing frame sandblasted, painted, and new axle (with brakes) installed. My frame is solid, not bent or twisted, etc., and therefore didn't need any further work. The shell dropped back in with no sizable gaps. If you still have the previously 'bent' frame, I'd be checking the accuracy of your newly, rebuilt, replacement frame. I do realize there is a small amount of 'play' between the shell and the frame; but, I believe my shell is adequately supported at all contact points. As suggested by Paul Nieumeister (the Ontario 'Guru' for any Boler repairs), I did have a welder ADD four angle-iron tabs to my frame; near each of the four corner contacts; and have now installed four 3/8 by 1 1/2 SS bolts, and fender washers, for additional security. I wasn't impressed with previously having only 16 'screws' holding the FG shell to the frame. Good luck with your trailer body-frame allignment.
bullfrogeh is offline   Reply With Quote
Old 08-16-2015, 02:31 PM   #4
Ian G.'s Avatar
Because the body was on a bent/broken frame for some time the body shell has twisted into that "crooked" shape. I am confident the body will go back into its original shape just don't force it quickly. Using the mounting bolts slowly tighten them down gradually over a few days to a week. If you tighten them too quickly cracks will probably develop.
Old 08-16-2015, 02:43 PM   #5
Timber Wolf's Avatar
North Florida
Good advice, don't be in any rush to tighten them, might take quite a while (weeks or months) it did not get crooked overnight. I would check to see that the new frame is really flat though, stuff happens sometimes.
Old 08-17-2015, 08:09 AM   #6
Johnny M's Avatar
Deep South
I agree with Ian, also letting it sit outside in the summer sun a couple of days will help as the fiberglass heats up it tends to become more flexible
Old 08-17-2015, 02:20 PM   #7
bullfrogeh's Avatar
I too - agree with Ian's advice (from the northern climate); and Tim and Johnny's advice (from the southern climates). So - I'm pulling my unit out of the shop for it's summer 'break' (Ooops - wrong word in this context !) before the snow starts ;D
Old 08-19-2015, 02:37 PM   #8
Trailer: 74 Boler (wip)
Its amazing how all of these issues are the same, I just did the same thing. The left side of my frame snapped right off. I used the plans from Ian G.'s web site (thanks Ian) to get a new frame made. When I went to fit the boler back on the frame there was a 1/2" to 1" gap in the center area. I hooked the boler up to the truck, took it over some speed bumps, that settled it down a bit more, then I installed 8 SS bolts, washers and lock nuts. I hope it flattens out more over time.
cdimarco is offline   Reply With Quote
boler
Boler frame help needed BC Lower Mainland valinnes Problem Solving | Owners Helping Owners 12 04-25-2016 05:56 PM
Crack in 72' Boler Frame-looking fro help! James N Towing, Hitching, Axles and Running Gear 9 08-26-2014 10:30 PM
1974 Boler 1300 Frame removal Suggestions/Help? TedN Problem Solving | Owners Helping Owners 7 08-29-2011 05:48 PM
New Frame for a Boler Cheryl Lee Problem Solving | Owners Helping Owners 2 01-28-2008 09:13 AM
