New Burro owner, FRV member - Fiberglass RV
Old 02-03-2016, 12:15 PM   #1
Trailer: 1981 Burro - 13'
Ohio
Hi, I'm Jim, from Cincinnati and Deb and I just bought a 13' '81 Burro. It needs a lot of TLC (and dollars!) but I hope to bring it back to life for my retirement trips! If anyone has "been there, done that" and can help me with ideas, advice and so on, I'd really appreciate the help. As a start, I'm looking at replacing the wooden floor (with 2 laminated layers of 1/2" aircraft/marine plywood, FULLY fiberglassed) and putting the shell back on. I've gutted the insides; water damage and mold made that imperative. Frame and shell both seem solid, will need painting and tweaking; replace coupler, etc.. This is a big project but I'm confident of my ability to DO it, and look forward to using it down the road. Thanks in advance for your comments/help, and I look forward to maybe meeting some of you soon!
CapnJim is offline   Reply With Quote
Old 02-03-2016, 12:25 PM   #2
If you are laminating why not laminate blue foam board between two sheets of 1/4 plywood?
Sent from my SCH-I605 using Fiberglass RV mobile app
Old 02-03-2016, 05:44 PM   #3
Ohio
Found out via another member that the wood has to be in 4 pieces that are bonded AFTER they are placed onto the flange at the bottom of the outer shell; they have to be separate to get them in place! Not sure how I'd put the foam in, may have to "punt" and use just one thick ply and route a tongue and groove into the meeting edges, or something like that. Once you get the floor inside the shell, and bonded, then you put the whole thing back on the frame and screw it down. I had thought the shell sat ON the floor; not so. Thanks for the suggestion anyway; I want the floor to be SOLID and hold up, I'm not a midget!
Old 02-03-2016, 06:56 PM   #4
Myron Leski's Avatar
Trailer: 19' Escape
NM
I had a 1981 Burro I did a lot of work on.
Go to U-tube and do a search for "Burro rehab project."
You'll also find others there. Myron
Myron Leski is offline   Reply With Quote
Old 02-03-2016, 08:08 PM   #5
Ohio
Thanks!
Old 02-04-2016, 09:53 AM   #6
Trailer: Burro
I know that three-quarter inch ply is available as pressure-treated, tongue-in-groove. I'm sure I've seen it at Home Depot. I am beginning a similar project with my early eighties Burro. My floor needs replacement, not because of moisture, but due to an infestation of carpenter ants. They tunneled between the layers of fiberglass, establishing a very cozy nest for thousands of the little bastards. This experience leads me to the desirability of pressure-treated ply.
Lynn
davisoly is offline   Reply With Quote
Old 02-04-2016, 10:23 AM   #7
Trailer: Burro 1983 13'
Wisconsin
Congrats on the Burro Jim.
I have had mine just under two years
and really have enjoyed it. Have fun!
Burro Bill is offline   Reply With Quote
Old 02-04-2016, 11:56 AM   #8
Ohio
Wonder if treating it with something before I fiberglass it would work, too? I want a REALLY strong floor; treated ply might not be quite stout enough but it's a good idea! Have you figured out a way to lift the shell and get to the existing wood for a pattern? Seems like rolling it on it's side is risky to the windows! Haven't figured out that little detail, yet! Good luck with yours; keep me posted, I'm going to be hit and miss on working on mine.
Old 02-04-2016, 11:58 AM   #9
Ohio
Thanks, Bill; I'm looking forward to getting mine out on the road. It's a basket case right now, but has good "bones". Lots of work, should be a good investment if nothing else! Hope my Mariner Hybrid can pull it OK! Wish me luck.................
Old 02-04-2016, 07:29 PM   #10
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Hi Jim, Congrats on your camper. We aren't too far away from you - we're in Kentucky. We adopted an old scamp last November, also rehabbing. Will be fun following your progress!
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Old 02-04-2016, 08:09 PM   #11
Ohio
Where in KY? We'd love a chance to see what you've done to yours.....we have a thousand ideas, not sure what would work or not! Not sure of our time frame; the rehab will be done around funds and time! Thanks for the shout; I'll be sharing what I can and asking about the rest, for sure. How far "into it" are you going?
Old 02-04-2016, 10:53 PM   #12
Wisconsin
Burro manual
Jim if you go to the documents section on here and go to
Burro there are some documents that might help you out
a little. As mentioned earlier You Tube but Google also has
some good videos and tips as well as photos.
Old 02-05-2016, 04:28 AM   #13
Ohio
Thanks; I've found a lot already; some of those projects are AMAZING! Almost too good to shoot for but I'll keep at it and see what happens. Thanks for the info and encouragement. Hope to meet you some time!
Old 02-05-2016, 10:43 AM   #14
Trailer: 1978 Burro
removing frame from Burro
CapnJim, I got to thinking last night about how I removed my frame. I took the bolts out from inside the trailer. I cut off the bolts from underneath flush with the frame they way when I tried to remove them I wouldn't have to try and run the rusty part back thru the threaded hole. I also tapped on the head of each bolt before I tried to break them free.
If you are going to remove the frame with the floor pieces still attached to the frame I might consider cutting the bolt heads off on top (4" angle grinder with cutoff wheel) and then using vice grips to unthread the bolts thru the bottom of the frame.
I always try an avoid bring a rusty thread thru a tapped hole. The rusty part has grown larger and is very tough to run back thru. Just thought I'd throw that out there.
My opinion is (of course everyone have a different one) that a complete overhaul of an old FRV is the best way to go. You can make it completely your own and eliminate all the extra weight too. I am in the process of replacing the particle board pieces with cedar. Probably about 1/3 the weight. Doesn't have the look of oak of course but some stain and some poly and I'm satisfied.
Good luck in your endeavor.
DuaneQ is offline   Reply With Quote
burro
I'm new to FRV's DuaneQ Hi, I am.... 4 10-18-2015 10:47 AM
2012 Bandon Oregon FRV Gathering Possum Oregon Gatherings 8 07-23-2012 10:41 PM
New to FRV Greg R. Modifications, Alterations and Updates 6 09-19-2009 05:50 PM
Help me FRV, you're my only hope! Anne Badgley Classified Archives 35 04-08-2009 09:12 PM
Need some education on FRV manufacturers Bruce Wray General Chat 19 01-11-2009 04:08 PM
