new fridge roof vent trouble fitting - Fiberglass RV
Old 11-18-2017, 04:43 PM   #1
I am replacing my roof vent because the old one was cracking and deteriorating. The new vent I got from scamp comes in two pieces (RM2410, RM2610). The problem is that the original vent was at the very edge of the trailer's roof where it starts to curve down the outer wall. The new vent has a flat base and so it does not sit flush against the curved fiberglass. I tried forcing it but it broke and I had to order a second one. I guess my best bet is to heat it up and try and reform it so the base is curved. Has anyone run into this issue? How did you remedy it?
samandallison is offline   Reply With Quote
Old 11-18-2017, 05:58 PM   #2
As is often the best thing to do, call Scamp and ask them how they manage.
Old 11-18-2017, 07:06 PM   #3
Yeah, I have tried this. The guy on the other end was no help. He couldn't even tell me what type of plastic it was made of. I have not had good experiences with them in general. I ordered a part from them 7 months ago and I have yet to see it.
Old 11-19-2017, 02:14 AM   #4
Many of us have had excellent customer service from Scamp. Maybe the trick is ask for one of Evelands, Micah or Kent. Eveland family are the owners.
I found the guy in the parts department most helpful and anything I've ordered comes fast. I don't order using the internet only by phone. 12 Years ago when I bought my trailer they didn't have a web site or email. All business was done in person or by phone, hence my suggestion is to "call' them.
Old 11-19-2017, 07:56 AM   #5
Trailer: none
I had the same problem, cracked the new base when installing. I gave up and reinstalled old base and used new cover. If I did it again maybe heating and forming would work, or what I was thinking building up outside edge on camper to make base sit more level, that is if you don't get a satisfactory answer on how scamp installed a straight piece of plastic on a curved roof?
Hambone is offline   Reply With Quote
Old 11-19-2017, 09:23 AM   #6
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
I feel like I ran into the same thing with my Bigfoot. I stacked more butyl tape under the area where the roof started curving down, and tightened the screws as much as I could to get the plastic to bend down, without breaking it. Then I used Dicor over that. So while it's not flush, it is leak proof. Warming the plastic, or at least doing this on a hot summer day sure couldn't hurt...
Old 11-19-2017, 12:16 PM   #7
Trailer: Bigfoot B-17 CB
As Zach suggested, I have also used multiple layers of butyl tape when resealing a window frame where there was a slight curve in the fiberglass. It worked well.
Old 11-19-2017, 12:48 PM   #8
Ya I have also tried double and triple up on the butyl tape but even then there is quite a big gap and my rivet still wont even contact the fiberglass.
Old 11-19-2017, 12:52 PM   #9
Three layers would be about the maximum I would be comfortable with.
Old 11-19-2017, 07:40 PM   #10
ZachO's Avatar
Montana
Wow, yeah that's a big gap. Hopefully somebody here or at Scamp can tell you how they made it work.
Old 11-20-2017, 07:56 AM   #11
Trailer: 2014 Escape 21
Virginia
PVC trim board
I run into this curve issue installing access hatches. Casita also has this issue with their water heater installation. I use white PVC trim boards to make fillers. The PVC can be cut and shaped with regular wood working tools to fill the space and fit the curve. The corners if required can be glued or screwed together if needed. Then use butyl tape on either mounting side of the PVC filler. You can usually get some small pieces from a house construction site. If you have to buy some it comes in 10 ft. pieces.
Eddie
Eddie Longest is online now   Reply With Quote
Old 11-20-2017, 08:30 AM   #12
ZachO's Avatar
Montana
That sounds like a good method.
Still makes me wonder how Scamp or the other trailers get it done without any of these methods, though...
Old 11-20-2017, 09:06 AM   #13
Eddie
Great idea. I wonder if someone sells a premade piece of fiberglass material that could be used this way.
Old 11-29-2017, 07:07 PM   #14
SUCCESS! The fridge roof vent is installed, almost. It still needs lap sealant, but the hard part is done. The trick to this repair is heat but not too much. First I tried to use a propane jobsite heater but it was too hot and the edges of the plastic started melting and the overall playability was not really effected. I talked to this guy who specializes in plastic welding and forming. From my description he didn't think that these roof vents are made of the type that can be welded. I still have yet to find out what type of plastic these vents are made of. He suggested that I use a heat gun which is like a hair dryer on steroids. I borrowed one from a neighbor, I used three layers of butyl tape but in hindsight two would have been enough. The more tape you use the harder it is to get that rivet to get as deep as it needs to. I started with the two opposite ones on the short side of the vent. Then, while under the tarp that is keeping water out. I went to town heating that vent up. I heated then drilled then heated then riveted, continued going from opposing sides each time until they were all popped. Don't try it without a heat gun or sure as shooting the vent will crack.
fridge
Trouble getting wire through Rat Fur for Fantastic Vent install Markz Problem Solving | Owners Helping Owners 11 06-19-2016 09:44 PM
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Fitting new wood deck in Scamp 13 Cindy D Problem Solving | Owners Helping Owners 2 03-20-2014 09:31 PM
Protecting The Roof & Roof Vent Covers , AC, This Winter ???? John Cole Care and Feeding of Molded Fiberglass Trailers 25 01-15-2013 05:57 PM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
» Virginia Campgrounds
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
