New old stock uhaul side windows - Page 11 - Fiberglass RV
Old 10-12-2012, 02:24 PM   #141
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by mary and bob View Post
I'm happy with the AS1456 weatherstrip that I bought. The only thing is that it is a little narrower than the original. Tom, do you have any of the new weatherstrip that you used left over, if you do I'll send you a little piece of the 1456 so you can compare them.
Bob
Yes, I still have a few feet.
Old 10-12-2012, 02:24 PM   #142
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
The secret tube on our VT was empty when I found it a couple years ago. No end plugs, either. I haven't had the chance to look under my frame for the VIN plate yet. Maybe in the spring! To tell the truth, I'm not all that eager to crawl around under my trailer since I'm a bit wider than the space between the trailer and the ground.
Old 10-16-2012, 07:18 PM   #143
Pam Garlow's Avatar
Trailer: U-Haul 1985
My camping season is pretty much over after October, so I'll be (gulp) tackling the window replacements. First step will be to take out the passenger side window, clean up the opening and then reinstall my nos window. Oh, yeah, I have to order the weatherstripping and installation tool.
Old 10-17-2012, 11:56 AM   #144
Perk's Avatar
Trailer: U-Haul VT 16FT
Kevin,
Can you clue me in on the "secret tube" as I am unaware of it. Where is yours and what is/was its function.
Thanks
Perk
Perk
Enjoy the Adventure
1985 16ft U-Haul VT
Perk is offline   Reply With Quote
Old 10-17-2012, 01:55 PM   #145
Thomas G.'s Avatar
Originally Posted by Perk View Post
Kevin,
Thanks
Perk
Underneath, just in front of the rear bumper, there is a steel tube about 3/4" in diameter and 6 " long with a plastic plug in each end mounted parallel to the bumper. It contained the original registration.
Old 10-17-2012, 05:08 PM   #146
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Found it
Ahh...had wondered what that pipe was, so excited to read about it because my CT13 is listed on the title as a homemade trailer. I poped it open today and found only an empty clear tube inside. HA! But now we have a place to hide tiny little things huh.
D Davis is offline   Reply With Quote
Old 10-26-2012, 12:44 PM   #147
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Original CT VIN plate
I'll just have to wait with bated breath.
Hello Mr. Bob and Mr. Tom,
Now you have me waiting with 'bated breath' to find out if you located those VIN plates yet?
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 10-26-2012, 01:18 PM   #148
Thomas G.'s Avatar
OK, I looked. There is a plate where you designated, but mine just says "Property of UHaul, Not to be Resold."
Old 10-26-2012, 01:29 PM   #149
I was under our Uhaul last weekend checking things and replacing some of the body bolts. I could not find either the VIN plate or the document tube. I looked all over the frame and found nothing, I had the trailer up on ramps so I had some room to work and look. I think I recall Tom [or someone] saying there was some ID plate on the inside of the cabinet door that is below the sink. We don't have that either. Ours has the remains of the VIN in three places, on the bottom of the front window frame, looks like it may have been label maker tape, in deteriorating condition. Second place is a sticker below the left front side amber reflector, partially scraped off and the words "designed by" can be seen on it, and some of the VIN. The third place is on the rear of the body, just above the bumper and to the left of the body seam, looks like numbers have been removed and painted over.
Old 10-26-2012, 01:48 PM   #150
Thomas G.'s Avatar
I've only seen the VIN on the aluminum sticker under the reflector on the driver's side. The tongue has various plates welded on saying "property of" / "not property of UHaul".
Old 10-26-2012, 02:11 PM   #151
no plates welded on our tongue, "Uhaul" is stamped in it
Old 10-26-2012, 02:45 PM   #152
djtriceflt's Avatar
No data on VIN plate?
Mr. Tom,
That is interesting as it is the first one of 4 I have inspected that does not have the additional VIN and date of manufacture on the plate. Sorry, your's does not but if it is a stainless plate maybe they started doing it after your production number?
Mr. Bob,
It is located immediately behind the drivers side (USA) left wheel wheel on an interior vertical flat frame surface that is several inches behind where the tubular chassis (pipe/frame) is welded to it. It was heavily painted over and I could only detect it by cleaning away the paint between two small vertical welds , which are also easily overlooked.
Who ever was behind this clever coverup of the VIN is to be either congratulated or cursed depending on your individual perspective! I guess, for some, the hunt is still on!
Old 10-26-2012, 03:17 PM   #153
Thomas G.'s Avatar
It is located immediately behind the drivers side (USA) left wheel wheel on an interior vertical flat frame surface that is several inches behind where the tubular chassis (pipe/frame) is welded to it. It was heavily painted over and I could only detect it by cleaning away the paint between two small vertical welds , which are also easily overlooked. ........
Mr. Don,
Maybe I misunderstood you. Does the plate face the center of the trailer or the outside? The plate I saw faced outward, i.e. was welded to the outer surface of the flat frame behind where the tubing is attached.
Old 10-26-2012, 04:23 PM   #154
Here's where I just looked. On the inside vertical surface of the driver side frame rail. The rail that runs front to back. To the rear of the round tube crossmember, the first one to the rear of the trailer from the wheel, there is a space about 12" long between that crossmember and the rear crossmember, there is one through bolt there that is for the bumper support on that side, there is another bolt farther forward. So is that 12" space on the inside of the frame rail where I should be looking? If so there is nothing there, the paint is so thin it wouldn't hide a plate or welds.
uhaul, windows
Uhaul Side Windows RICK H. Problem Solving | Owners Helping Owners 80 12-12-2016 05:07 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
LiteHouse side windows. Davie B Problem Solving | Owners Helping Owners 6 03-15-2012 06:13 PM
scamp side windows... nancy and steve Problem Solving | Owners Helping Owners 0 05-28-2011 10:00 AM
Boler Side Windows Kevin M Problem Solving | Owners Helping Owners 2 08-05-2008 09:02 PM
