New old stock uhaul side windows - Page 12 - Fiberglass RV
Old 10-26-2012, 07:34 PM   #155
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Originally Posted by Thomas G. View Post
Mr. Don,
Maybe I misunderstood you. Does the plate face the center of the trailer or the outside? The plate I saw faced outward, i.e. was welded to the outer surface of the flat frame behind where the tubing is attached.
Mr. Tom,
That is correct, it faces outboard so you can read it just by kneeing down. It is only welded with very thin vertical beads at the leading and trailing edge and the plate is not much larger than a drivers license. The fact that they painted over it was very clever so as to hide it! (thieves, etc.) Scraping the paint off (or using paint remover) between those welds reveals the data plate...
Both of the other CTs at the rally had them but their owners were also
unaware they were there until we looked together...
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 10-26-2012, 07:49 PM   #156
djtriceflt's Avatar
Originally Posted by mary and bob View Post
Here's where I just looked. On the inside vertical surface of the driver side frame rail. The rail that runs front to back. To the rear of the round tube crossmember, the first one to the rear of the trailer from the wheel, there is a space about 12" long between that crossmember and the rear crossmember, there is one through bolt there that is for the bumper support on that side, there is another bolt farther forward. So is that 12" space on the inside of the frame rail where I should be looking? If so there is nothing there, the paint is so thin it wouldn't hide a plate or welds.
Mr. Bob,
Just by kneeling down, in front of the rear bumper and behind the left wheel well,you should be able to see that flat vertical frame section you described and then see two thin vertical weld beads about 2" long and about 3 1/2 ' apart that are located about 2" aft of where the outer curved tubular frame section is welded to that interior section (angle iron) you described. If it's not there, maybe they did this later in the production run or at one of the
production sites but not at another?
Old 10-27-2012, 12:44 PM   #157
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
I have a plate there that says "not uhaul property" however, it appears to be welded over top of another plate.
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 10-27-2012, 04:55 PM   #158
I looked again, no plate, and no evidence that there ever was one!
mary and bob is online now   Reply With Quote
Old 10-27-2012, 08:29 PM   #159
djtriceflt's Avatar
Sorry it was not there as I know you would have liked to have it instead of
having to make one...
Old 10-27-2012, 08:31 PM   #160
djtriceflt's Avatar
Interesting!
Old 10-27-2012, 08:40 PM   #161
We must have an early '84, Don when we get to Florida you can come look, and yes I would have liked to have it. But what I like the most is how everyone here shares information and knowledge, that makes this a great site!!
Old 10-27-2012, 08:49 PM   #162
djtriceflt's Avatar
Mr. Bob,
Absolutely agree!
Old 10-28-2012, 12:56 PM   #163
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I noticed that they are down to the last three windows and two are missing a handle and one is missing a piece of glass. Last chance!
Old 10-28-2012, 12:58 PM   #164
Thomas G.'s Avatar
I was tucking mine in for the winter and slid underneath to take these pictures.
Old 10-28-2012, 01:59 PM   #165
I was wondering if the supply was going to run out! Probably they are all right side windows?
Old 10-28-2012, 02:08 PM   #166
Thomas G.'s Avatar
Yes, ad now says passenger side only.
Old 10-29-2012, 10:26 AM   #167
djtriceflt's Avatar
Mr. Tom,
Thanks for posting those pics. That is exactly the plate and location but it apparently your numbers were not stamped on it like the others I have seen.
Here is the plate on my #2 unrestored CT. Note the VIN at top and
date of man. below...appears they may have decided to start stamping the numbers on that plate a little later in production , before it was welded on, as the numbers are definitely hand stamped.
Old 10-29-2012, 11:29 AM   #168
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Originally Posted by djtriceflt View Post
Mr. Mike,
Unless the VTs were done differently, which is very possible, you may have another s/s plate as well...
got around to cleaning it off with a wire brush on a drill and indeed it is SS but the VIN numbers are different than the sticker only the last 6 agree. photos attached
mmeyer is offline   Reply With Quote
uhaul, windows
Uhaul Side Windows RICK H. Problem Solving | Owners Helping Owners 80 12-12-2016 05:07 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
LiteHouse side windows. Davie B Problem Solving | Owners Helping Owners 6 03-15-2012 06:13 PM
scamp side windows... nancy and steve Problem Solving | Owners Helping Owners 0 05-28-2011 10:00 AM
Boler Side Windows Kevin M Problem Solving | Owners Helping Owners 2 08-05-2008 09:02 PM
