New Scamp parts don't fit my old egg - Fiberglass RV
Old 11-05-2007, 09:48 PM   #1
Trailer: 1985 Scamp 16 ft
I'm running into trouble repairing a few problems with my Scamp 16. The black rubber collar that fit between my sink drain and the drain line (just a garden hose, in my model) has splt in half due to age. I called Scamp and asked for a replacement, and they sent a white, screw-on plastic fitting that's twice the diameter. "No, send me the old style," I requested, until the parts guy (Kent) insisted he'd worked there 20 years and "they've always been made this way." That's almost long enough to have watched my 1985 model roll off the assembly line.
Then I asked him about the door latch assembly he sent me. My trailer has a round exterior door knob, not a lever like the part they sent me. None of the bolt holes match, so mounting the new latch would be a chore. Once again, Kent insisted this was the only door latch ever used.
He challenged me, asking "Are you sure it's a Scamp?" Well, it was titled as a Scamp, and has four Scamp decals, and the interior is covered in beige rat fur, so I'm fairly sure it is. But for the unavailability of direct replacement parts, my Scamp might as well be one of those rare old small-production brands.
Has anyone else ever faced these repair issues? If so, what are some answers? I can tolerate my worn old door latch if a locksmith can repair the lock cylinder so I can lock it. Does anybody have a sink drain like mine, with a black rubber collar that's 7/8ths-inch inside diameter? Where is it obtainable, or what makes a good replacement part?
John Mc is offline   Reply With Quote
Old 11-05-2007, 10:12 PM   #2
Trailer: Evelands Inc. Scamp 5vr
I could be wrong but I dont think that a 1985 Scamp had rat fur, it should have had Elephant hide or what ever they called it.
Blair
McClure is offline   Reply With Quote
Old 11-05-2007, 10:17 PM   #3
It sounds like somebody has made several changes or it's not really a Scamp. Kent, by the way, is the Kent Eveland, the owner.
You might want to call Kent back with the vin number and have him check the manufacture date.
Old 11-06-2007, 06:05 AM   #4
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
My Scamp experience started in 1980 with a 1978 model. I don't believe I've ever seen a Scamp with anything but the lever door handle either. The suggestion to call Kent back with the VIN is a good one.
Roger
Old 11-06-2007, 06:44 AM   #5
Alf S.'s Avatar
Hi: Sounds like you have the previous owners disease. 99% of the Scamp parts I bought fit our '77 Boler and thats 30 yrs after it was "Laid" Try emailing some Digi Pic's of the parts you need...or take them to a local R.V. dealer and check there.
Alf S. is online now   Reply With Quote
Old 11-06-2007, 06:48 AM   #6
I believe Scamp didn't start putting Rat Fur inside until mid-model year 1987.
Here's a link to the Scamp VIN Decoder....
Scamp VIN Decoder
Old 11-06-2007, 07:27 AM   #7
Ed Harris's Avatar
This may not be important to this specific question but I learned yesterday from Scamp that they will not promise that any molded body parts will fit on "Pre-Fire" trailers.
I was looking at another trailer and wanted to know the possibility of adding a shower where there is none.
I was told that the new molds are not eggsactly(sorry I can't help it) the same as the old ones and that even the construction details are somewhat different.
Just F.Y.I.
Ed
Ed Harris is online now   Reply With Quote
Old 11-06-2007, 12:39 PM   #8
I'm impressed by the number of quick responses to these questions, though the answers are still pending. The number plate is undecipherable without using a microscope. Looks like it was painted over at one tine, then sanded. I'll check the state registration tonight, when the tow car returns home. But I'd bet the whole thing that it's a bona fide Scamp. It looks like every other Scamp I see, just without most of the amenities.
The sink is beside the closet, opposite the cooktop. It has a small drain, unthreaded, which I need to step to a hose thread. It's mounted in white fiberglass, which matches the opposite cabinet boxes. I've already described the door latch differences. Nobody could have switched between these latch styles without lots of leaving old screw holes on the door, and there are none. It all loks like original work to me.
I'd post pictures if I knew how. Is there really a 400 kb limit for attachments, or is it 400 each?
Old 11-06-2007, 03:01 PM   #9
Administrator
Mary F's Avatar
Actually, we prefer that pics be less than 80k. At 72 dpi and 500 pixels wide, that's perfect for downloading, even for our members who use dial up connections. Thanks for asking.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 11-06-2007, 04:00 PM   #10
Brian B-P's Avatar
400 kb total for one post (any number of images), but that's enough for a few nice clear photos. I occasionally run over that, but usually find I've just used a larger than necessary file an image.
I often use dialup, and appreciate restraint in file size.
At 500x500 pixels, colour image files (such as JPEGs) will easily be much larger than 80 kb unless you adjust the "quality" to something less than 100%... I usually use 80% and hit reasonable file sizes. The DPI setting is irrelevant except perhaps in your photo program's calculations; the actual image size in pixels is the important part.
The Basic Website Tutorials section has all you ever wanted to know about posting photos (and more).
Old 11-06-2007, 04:06 PM   #11
OK, here goes... I'm attempting to upload pics of the drains and door latches.
Old 11-06-2007, 04:21 PM   #12
Roger H's Avatar
Iowa
John, how 'bout some photos of the trailer itself. The parts you're showing are not like anything I've ever seen on a Scamp.
Roger
Old 11-06-2007, 04:38 PM   #13
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
John- --was looking at yer photos.....Hmmm Betcha if you take the door knob mech off, you'll find some more holes under that plate on the outside. And on the inside shot, is that a hole just below the latch mechanism? You might be surprised as to what you find under there. As for the sink drain, are those saw marks on the PVC? Maybe my eyes are deceiving me, but that is what it looks like to me. You might have to find a PVC sleeve or coupler to slide over that and then go to pipe/hose thread fitting. (with a liberal amount of PVC cement...) Larry
Larry&Carrie is offline   Reply With Quote
Old 11-06-2007, 04:46 PM   #14
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
I remember seeing someone posting an old ad from the days that Scamp sold trailer "kits" that the buyer then assembled. Any chance they sold 16 footers that way and the buyer deviated a bit?
I'm looking forward to the pics of the trailer - it looks pretty scampish to me though.
Earlier poster is correct that Scamp doesn't start using the ratfur till '87 - but titles get screwed up all the time.
If anything - I'd like to see more photos just to see if there are other ways the trailer differs from a normal Scamp.
Mike
Mike Watters is offline   Reply With Quote
scamp, eggcamper
Scamp Camper Parts Kevin K Classified Archives 0 05-01-2010 05:57 AM
PARTS ARE GONE - scamp parts for sale Judith Kennedy Classified Archives 1 03-04-2010 06:08 PM
Buying Parts from Scamp Vicki A. General Chat 3 01-20-2010 06:28 AM
Scamp Brake Parts Don Fowler Classified Archives 3 04-21-2007 08:33 AM
Scamp parts John Perry General Chat 4 10-19-2006 05:56 AM
