New Trailer Issues - Fiberglass RV
Old 08-19-2018, 12:37 PM   #1
Trailer: Bigfoot 25RQ
Mississippi
New Trailer Issues
We just replaced our fiberglass trailer with a new Bigfoot 25RQ. There is an issue I cannot find an answer to.
Our hot water heater will not work with gas or electric it's an attwood ac/propan. The control module is blowing fuses so I understand why the gas system isn't working.
Does anyone know if the AC side of the water heater should work if the control module is bad?
snuffy2 is offline   Reply With Quote
Old 08-19-2018, 12:51 PM   #2
This is one approach. You'll get lots of answers, most worhtless. My suggestion get the model number look up on the internet Atwood's repair locations, given them a call. It if requires to go to shop contact make sure you have warranty information with. Many component supplies have a 2 to 3 year warranty.
Old 08-19-2018, 01:17 PM   #3
Mississippi
testing
It arrived tuesday, tried the hot water heater friday found the fuse blown. Going to check the heating element with multimeter to see if it's bad this afternoon.
I didn't know that attwood was now owned by dometic till I started looking at this stuff.
Old 08-19-2018, 01:21 PM   #4
Tank is full of water?
Old 08-19-2018, 02:15 PM   #5
Mississippi
Tank
Tank is full of water, it is not bypassed. Heating element is showing 10.4 ohms resistance. No power though to the terminals, Thats what I'm trying to find out, if the control module is bad for the gas operation will that also shut down the electric operation of the heater.
The control module blows fuses so there is definitely something there.
Old 08-19-2018, 03:34 PM   #6
Name: Bruce & Kathryn
Trailer: Bigfoot 25 RQ
I’m surprised this was not discovered during your walk through. Odd. I assume propane tanks are full and open, and your house battery (batteries) are fully charged. In the spirit of keeping it simple, I also assume the MW/HW switch is on HW, and the Gas or Electric select mode select switches are on the aporopriate mode.
Bruce Olive is offline   Reply With Quote
Old 08-19-2018, 03:39 PM   #7
I have a new 25RQ as well. Out at it right now. So it’s the 2 amp controller fuse that’s blowing? And it has blown after replacement? If that is so, should get a warranty replacement of the control module. Just two screws hold it in. I would start with that.
Old 08-19-2018, 03:47 PM   #8
Mississippi
Controller
Thats the same conclusion I've come to about the controller.
We didn't do a walk around due to buying it almost 3000 miles away and having it shipped to us.
Old 08-19-2018, 03:58 PM   #9
Clarifying my previous post
Just thought I would attach photos of the switch positions I mentioned in my previous post. The microwave/hot water heater switch has gotten me in trouble on occasion when I told the wife there was hot water and then...oops, there was not. Good luck, and please let us know the outcome. We had ours shipped 3,000 miles from BC to North Carolina, but fortunately we have a local dealer. I would imagine Grant would ship you a new controller, or help you get one from a local source under warranty. Sorry for your troubles.
Bruce
Old 08-19-2018, 05:40 PM   #10
Mississippi
Yep, ours is identical to that.
Old 08-25-2018, 10:32 AM   #11
Mississippi
Controller
Bad controller and it does shut down electric and gas when it goes out. Makes me wonder, I was told everything was checked before it left the dealer.
Working on a few more issues that need solving, wife isn't happy!
Old 08-26-2018, 07:49 AM   #12
Trailer: Escape
Illinois
Warranty
I have a 1 yr old Escape with a suburban water heater, gas-electric. Picked it up last July. Tested ok before I took ownership. A few weeks out, the gas portion stopped working. Checked the obvious switches, etc.abn called Escape.
In general I recommend calling the manufacturer or dealer first. In this case and others I gave found them very responsive.
They asked some questions, noted that it was the circuit board and directed me to call surburban as it was a warranty issue.
In general I recommend calling the part manufacture at this point before you void the warranty.
I called Surburban and they confirmed the problem and directed me to some authorized dealers. Non of the dealers were willing to take on the work. Most wanted to sell me a Dinosaur Electronics board. I finally found a dealer who laid it out for me.
It was peak season. If this had been November he would have taken on the warranty work. But, it did not pay enough, there was paperwork and payment delays involved. He recommended the Dinosaur board, told me where I could obtain one and gave instructions. The board solved the problem - and the are very cell made.
My approach to these kinds of problems is similar to those who recommend taking the Warranty route. I only took direct action in the beginning to test. In the end I only took direct action when I clearly understood the issue and realized that Warranty in this case was not very helpful.
Little Richie is offline   Reply With Quote
Old 08-26-2018, 08:13 AM   #13
I almost hate to have a warranty, because of the hassles.
I am lucky in that I can fix almost everything, given access to the internet and parts.
Steps.
1. Determine symptoms
2. Google symptoms
3. Google parts
4. You Tube repairs.
5. Buy more parts.
6. Repeat as necessary
Old 08-26-2018, 08:23 AM   #14
Mississippi
Board
Yeah we figured it was he board after we check everything else with multimeter. They still wanted the camper to be towed to an authorized repair place. We got lucky found a guy who said bring the piece in and he would check it no charge, it was bad he called attwood/dometic and has a new replacement on the way.
What model of dinosaur board?
Too much tongue weight - trailer frame/coupler issues? Joe & Cherie Towing, Hitching, Axles and Running Gear 39 10-28-2017 04:06 PM
Brake issues on Bigfoot 21 ft. Trailer Sandstone Towing, Hitching, Axles and Running Gear 16 08-17-2017 04:07 PM
A few new Scamp issues WDavidG Problem Solving | Owners Helping Owners 20 07-23-2014 10:33 AM
Bleah- yet more trailer light issues Bobbie Mayer Problem Solving | Owners Helping Owners 16 08-26-2013 06:26 PM
New (to us) Scamp... with some issues to work out Crystal B Problem Solving | Owners Helping Owners 18 04-27-2009 03:59 PM
