New Water system for 76 Boler - Fiberglass RV
Old 05-08-2015, 06:19 AM   #1
Hi,
I am wanting to configure a water sytem where I just hook up the camp site water supply to the trailer and plumb it so that the water goes directly to a tap. ( avoid a holding tank). Of course this system is good only for when there is a water supply to hook up to, but my wife and I have no plans to do any wilderness camping. I have removed the external input nozzle and the galley pump tap. Where can I buy the plumbing supplies what I need to make this happen.
Thanks in advance for any input.
Michael
Flesherton ONT
Canada
michael386 is offline   Reply With Quote
Old 05-08-2015, 06:41 AM   #2
Ian G.'s Avatar
Did your Boler have 2 taps at the sink, one with a pump and one with a normal twist handle? If it did the Boler was already set-up for exactly what you are wanting. The pump faucet uses the reservoir to supply water, the "normal" faucet is plumbed directly to the outside fitting that connects to a garden hose.
Old 05-08-2015, 02:55 PM   #3
Thanks Ian,
There was only one "pump" faucet. So it was set up for use of the reservoir. What you describe is an ideal system....but I will just pursue the direct plumb model
Old 05-08-2015, 03:31 PM   #4
Ian G.'s Avatar
On the outside the fitting you removed, is it like a tray or "cup" where water fills the reservoir? Is the any garden hose type connection on the outside? I have never seen a Boler without the street water set-up unless a PO has removed it.
Do you have any pictures?
But in general it is very easy plumbing, garden hose connection on outside (available from any RV dealer. Any faucet you like on the inside, you can use an RV faucet or a home bathroom, bar, or kitchen faucet. and then a water line between the two.
Old 05-09-2015, 07:23 AM   #5
Ian,
It is a female garden hose connection on the outside of the boler. My intention is to do just as you suggested....in fact I have purchased most of what I need.
Thanks again
Old 05-09-2015, 09:19 AM   #6
Yes and it will look like any of these. The original ones found on most Bolers I have seen was a small chrome one. Surprised yours does not have one as it was a stock item.
Old 05-09-2015, 10:58 AM   #7
thank you....I guess I was not clear in my description. I do have the chrome one. Again, I think I have it problem solved now.
Thanks Ian and carol for your help.
boler
water system in 1974 Boler tremmert Problem Solving | Owners Helping Owners 11 09-03-2012 05:49 PM
U-haul VT-16 Water system Matt in SV Plumbing | Systems and Fixtures 6 05-17-2010 08:17 AM
13' Scamp Water system diagram Wilder Plumbing | Systems and Fixtures 4 08-26-2009 07:52 PM
Losing prime in water system Paula D. Plumbing | Systems and Fixtures 19 06-07-2006 12:58 PM
Water system jefh Care and Feeding of Molded Fiberglass Trailers 6 01-17-2006 02:27 PM
