newbie - leaking roof - 74 trillium - Fiberglass RV
Old 08-11-2011, 10:20 PM   #1
Trailer: '74 trillium 1300
so, yeah, i very recently joined the club, about to take her on the maiden voyage and the roof is leaking on the 74 trillium am about to call home. it appaears it's leaking thru the fiberglass and drips down the moldings between the whatever it's called on the inside.
i checked the roof vent thoroughly and it appears watertight.
discovered a few minor surface holes and cracks, but on the other side, so pretty sure it's not the source. duct taped them all [just to check] and then tried the hose again and still leaking.
the roof is pretty solid - does have some surface pocks from hail or road grit, and a few bare brown patches.
fiberglass leaks? what do i do? will not have time for any major repairs before i leave.
suggestions [besides do a search - lol].
help appreciated.
tnx
dune is offline   Reply With Quote
Old 08-12-2011, 04:40 PM   #2
Raz
Raz's Avatar
Vermont
Welcome Dune. We just finished solving a leak problem. Tough nut to crack, especially when all you see is a puddle coming from behind the wall covering. Are you sure it is the roof. If so, leaking roof vent, awning guide, door drip, etc. I would rebed them with butyl tape. I used duct tape to isolate my leak. Ended up resealing several windows and the belly band. Do a search for my and other posts. I am sure others will have suggestions. Good luck,Raz
Old 08-12-2011, 07:29 PM   #3
tnx
But is it really? Water is like mice... it only takes a tiny little area to cause lots of damage. I'd cover it and tape it up and run a hose over the top to make sure. Resealing a roof vent is an easy fix.
Old 08-12-2011, 08:11 PM   #4
did that. it was completely sealed. ran the hose...drip drip drip.
it's not a window, or belly band. it's the roof itself.
i suspect it's a few spots where the paint was thinner or worn to brown, looks like there was some spots [and i mean 10 places] where there was hail or rock damage that someone bondo'd previously, they don't appear deep.
someone suggested a new coat of good paint would help seal the tiny pores?
does that make any sense?
Old 08-12-2011, 08:23 PM   #5
Chris & Maureen had a Bigfoot 5th Wheel with roof problems, check out this direct link for their solution: 1984 Bigfoot 5th Wheel Updates
Old 08-12-2011, 08:30 PM   #6
many thanks.
i suspect that's the route i will be going shortly, but won't have that done before monday when we head out...i'm thinking of tarping the top if we get rained on...not sure what i will do if it's really wet on a travel day, but will play that by ear.
Old 08-13-2011, 06:45 AM   #7
Time is running out, but if you're concerned about roof leaks and don't want to use duct tape for the holes (the glue turns to concrete!), you might want to get a roll of this stuff. You could probably find it locally, while NOT cheap neither is a bunch of roof leaks and the discomfort it causes while camping:
Amazon.com: Scotch(R) Weather Resistant Masking Tape 225 Silver, 18 mm x 55 m [PRICE is per ROLL]: Industrial & Scientific
"Scotch(R) Weather Resistant Masking Tape 225 has a silver coating on the crepe paper backing which reflects ultraviolet light to provide outdoor weather resistance for up to 30 days. This tape should be dry before unmasking."
Old 08-13-2011, 09:04 AM   #8
Trailer: 13 Trillium
Sorry to hear about your leak - I too am experiencing the "thrill" of tracking those little suckers down! I found a couple when I was contorting myself under the storage bins everywhere, trying to nail down the leak. My big moment came when I saw sunlight shining thru where it shouldn't have been. Maybe you could try looking at night. Kind of the opposite of me. I was in the dark and saw the light (so to speak) If you try doing this at night with no lights on, and someone else to shine a flashlight from the top - perhaps the same effect. Good Luck
lhanna is offline   Reply With Quote
trillium
Leaking Trillium Windows Paul Richter Problem Solving | Owners Helping Owners 20 05-16-2014 05:52 PM
Trillium Newbie! lhanna General Chat 18 08-11-2011 05:27 PM
Roof Vent Leaking ROIDON L Problem Solving | Owners Helping Owners 6 01-25-2010 06:39 PM
Leaking Roof Vent Dale C Problem Solving | Owners Helping Owners 6 04-09-2009 10:28 PM
newbie confused..which trillium to buy,,Outback (canada) or Trillium u lloyd cicetti General Chat 17 08-04-2008 07:46 PM
