Newbie with questions - Fiberglass RV
Old 07-17-2015, 10:37 PM   #1
Iowa
Hi all,
Well the 2010 19 standard arrived today!! What a beaut!! It's so cool, we can't wait to take it out!
Had a chance to go through it somewhat today and I have a few questions:
1) Both dinette lights as well as the dinette fan don't work. Went through the DC fuses and pretty well isolated which fuse controls what but I can't figure out what the top fuse in the box, a 20 amp, goes to. I'm thinking the lights and fan and perhaps the fridge (on DC) go to this. But the fuse is not blown so I'm pretty much at a loss on my next move. Anyone who may know the routing of the wires to the lights and fan (what fuse they go to) would be a big help. I also noticed a 4 amp fuse in the fan housing but can't figure how to remove it for inspection.
2) When I plugged in to shore power, the furnace came on (it's 95 degrees here today). It appears the thermostat doesn't work but I'm not sure. I disconnected the two wires which attach to a screw inside the thermostat and that shut it off. Also, pulling the fuse shut it off as well. Not sure on my next move here, if anyone can help..
3) After putting some water in the toilet, about an hour later the bowl was empty. Will I have to replace the seal on the valve, or is this normal? Since I don't see a vent of any kind on the black tank, I'm thinking water in the bowl might be key to - er - keeping odors at bay. Any advice on changing the black seal would be helpful.
4) The camper was winterized. When I ran the water, all of the antifreeze in the sink and shower lines was expelled and I am wondering if there are any valves that I need to open (or close) to de-winterize.
5) Finally, the Scamp does not have a battery. I am assuming when I get one, the positive (fused) wire and the negative wire (under the loft and dangling in the empty battery case) would simply be attached on the positive and negative polls on the battery, just like in a car. Is this correct?
Thanks in advance for all your assistance!!
Peter S. in Iowa is offline   Reply With Quote
Old 07-17-2015, 11:34 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Congrats Peter on the new rig. Can't help you as I don't have a Scamp but did want to say that I've had ATC type fuses look good with an eyeball but were blown where I couldn't see it. My meter found it though.
Borrego Dave is online now   Reply With Quote
Old 07-18-2015, 07:17 AM   #3
Carl Pa's Avatar
Hi, no battery !----- No lights, no fan, they run on 12v
Carl Pa is offline   Reply With Quote
Old 07-18-2015, 07:38 AM   #4
Trailer: 2014 Escape 21
Virginia
1. Pass
2. Turn Tstat to left detent to turn off. If turned on it will not immediately turn off it has to go through a shutdown cycle. Make sure it is in the detent and try reconnecting.
3. Clean and lube seal first. Info. in dometic inst. manual.
4. If Scamp winterizing inst were followed and the trailer stock. Open the valve goingto the WH under the sink. See Scamp manual.
5. Make sure wires are taped up and dont short out until batt. is inst. See decal for color code. +black -white.
Old 07-18-2015, 10:02 AM   #5
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
As to the toilet a recent post indicated that letting the valve snap shut would solve the problem , others replied that this solved the problem , worth a try .
Bob in Mb is offline   Reply With Quote
Old 07-18-2015, 10:18 AM   #6
Trailer: Bigfoot B-17 CB
It's my understating that the toilet valve does not necessarily keep water in the bowl. Its function is to keep most of the odor out of the trailer. A cleaning of the mating surfaces might help. You could have some debris stuck in there.
Newbie Questions Andrea General Chat 16 08-07-2006 08:57 AM
Newbie questions on towing/repair Sharyl Allender General Chat 23 05-28-2006 11:03 PM
Newbie: Hitch & wiring questions Anne H Problem Solving | Owners Helping Owners 8 05-20-2006 04:17 AM
fiberglass care questions from newbie ChrisB Care and Feeding of Molded Fiberglass Trailers 13 03-23-2006 11:25 AM
Questions from a newbie Legacy Posts General Chat 9 05-26-2003 03:39 PM
