10-19-2018, 03:32 PM
Kentucky
No 12v from TV
I have no evidence that 12V feed is reaching my Casita.
I have a 7 flat pin connector. Turn signal, brake lights and electric brakes all work perfectly, but it seems that no 12V power is reaching the trailer battery or the trailer's 12V circuits.
Using a multimeter, I find no current from ground (1) to aux power (4). This is true with ignition on or off and with the engine running.
The 2004 Trail Blazer tow vehicle was factory wired as part of its towing package.
What are the probable causes, or cause of this lack of current?
Thanks.
Jim
10-19-2018, 03:43 PM
Trailer: 1977 17' Boler
Saskatchewan
Thanks.
Jim
Most 12 volt system are fuse protected. Depending on many different trailer makes and wiring configuration, some were just wired to the auxiliary battery on trailer and for most the 12 volt feed is feeding to the 110/12 volt converter and then back to the trailer battery. I had the same problem this spring and could not figure why the trailer had no 12 volt power. I traced the wiring from the vehicle trailer plug to inside the trailer and after many gymnastic body contortions, I was able to locate inline fuse that I never knew existed.
10-19-2018, 03:46 PM
Mid Left Coast
was the ignition on and engine running when you did this test? many factory tow packages won't power the 7'blade until the vehicle alternator is charging
on my 2001 ford E150 we bought new, the tow package included a relay and fuse in a baggy in the glovebox, these had to be plugged into the main relay/fuse panel under the hood to provide tow power.
10-19-2018, 03:48 PM
Kentucky
Sounds like that's worth a look, but I have no voltage on the TOW VEHICLE, so maybe there's a fuse on that side too... That would make sense.
10-19-2018, 03:49 PM
Mid Left Coast
the fuse and relay I am talking about are on the tow vehicle side.
10-19-2018, 03:51 PM
Kentucky
Yeah, as I said in the first post, engine running or not, no juice.
"Tow package" means different things to different people (and companies). It is quite possible that a charge line is not considered part of the tow package for that vehicle. You would have to research it to make sure it is included, unless it was working and now it is not.
10-19-2018, 04:09 PM
If you were truly measuring current between these two points, that is, using the ammeter function on your multimeter, then you were placing a short between the two points which would certainly pop a fuse or breaker. Perhaps you ment voltage?
Many charge lines are relay activated. The relay will be fused. That's where I would start.
10-19-2018, 04:23 PM
Kentucky
Thanks.
I found what seems to be the fuse for that circuit (30 amp). Fuse not blown, but no power in fuse socket with the engine running. So, there must be a relay I don't know about. Will have to research it.
10-19-2018, 04:25 PM
Mid Left Coast
good catch. i read 'voltage'. if his meter was actually in a ma or amps mode, it would have blown a fuse inside the meter, which disables the amps/milliamps modes. those are very fast-blow fuses.
10-19-2018, 04:30 PM
Kentucky
Yes, I was measuring voltage, but thinking flow, both of which were zero.
Mid Left Coast
Thanks.
you measured the voltage from either side of the fuse socket to a good ground nearby? you can't measure the voltage across the two fuse pins, because there's no load plugged into the trailer socket.
10-19-2018, 04:44 PM
Kentucky
Ah. Right you are. I'll check again.
10-19-2018, 04:57 PM
Kentucky
OK....I get a 12V reading on one leg of the fuse socket, so, why do I get nothing from 4 to ground at the pigtail socket? Got to be another fuse or relay, or????
10-19-2018, 05:05 PM
Mid Left Coast
indeed, the relay, if there is one, is probably downstream from the fuse. power -> fuse -> relay -> socket.
I tried to find wiring diagrams for a trailblazer, but didn't have much luck... tons of bogus sites that all looked identical but didn't contain what they claimed and all offered a 'free 30 day trial subscription' with the most bogus hostnames.
a post on this forum https://forums.trailvoy.com/view.php?pg=resources suggested they have them in the 'resources', but not owning a TB, I didn't want to register and look.
you might just inspect under the back of the SUV near the RV socket, and see if you can follow the wiring harness forward from the RV socket, maybe there's an obvious breakage from snagging road debris or something over the last 15 years...
10-20-2018, 10:59 AM
Kentucky
John, that site was the solution. Posters noted that Chevrolet left the trailer power wire disconnected as standard procedure. It's a red wire with a flat connector near the fuse block. Just have to lift the fuse cover and attach the wire to a vertical screw with a wing nut.
All good now. Thanks everyone!
Jim
10-20-2018, 02:09 PM
Mid Left Coast
you might check if the trailer power is always on, and if it is, try to remember to unplug teh trailer when parking for a few hours so you don't run the vehicle battery down... or add an isolation relay between that wire and the terminal...
relay wiring, assuming its a standard bosch style relay with terminals 30, 85, 86, 87...
terminal -> 30
87 -> red wire
ignition power -> 86
85 -> ground
this way when the ignition is on, the relay is switched on and the trailer hitch is powered, otherwise if the ignition is off, the relay is off. use a relay thats rated like half again more amps than the fuse on the circuit (so, say, 45+ amp relay if its a 30A fuse).
