Old 01-13-2012, 10:32 AM   #1
Trailer: 1988 Bigfooit 19'
No Propane supply
Hi,
I have a 1988 16ft travel trailer with 2 tongue mounted tanks. The tanks are full and with the valve on but no gas in the lines.
The supply lines pass through the water heater and space heater before reaching the stove and refridgerator.
Is there any procedure at one of the other components that must be executed to supply gas to the trailer.
I have not found any cutoff valve...not saying it does not exist.
Any help would be appreciated.
Thanks,
Mitchell
jordo is offline   Reply With Quote
Old 01-13-2012, 10:55 AM   #2
I'd be checking the regulator.
Old 01-13-2012, 11:06 AM   #3
P. Raz's Avatar
Vermont
Hello Mitchell and welcome to the forum. Two thoughts:
-there is a flow regulator inside the tanks I have. It will sometimes "shut down" if the flow is too high. To reset it I close the the valve, disconnect the tank, and then reconnect the tank.
-might be a bad regulator.
Others more knowledgeable than I will chime in I'm sure. Good luck, Raz
P. Raz is offline   Reply With Quote
Old 01-13-2012, 06:25 PM   #4
WildBirder's Avatar
I have used an old hose that was "plugged" with dust due to no cap being used on it. If problems persist having your propane system inspected at an RV centre is a good investment. They will usually post a modest fee and it should really be done periodically anyways.
Cheers,
Mark
WildBirder is offline   Reply With Quote
Old 01-13-2012, 06:54 PM   #5
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Don't spiders love propane?
Old 01-13-2012, 07:06 PM   #6
WildBirder's Avatar
Yes!! That's what plugged the hose, spider webbing. Keep those things capped.
Old 01-15-2012, 09:58 PM   #7
I replaced the manifold and surprise!.....I got gas...the good kind. Thanks again for all the advise. I can promise that there is more to follow.
propane
Computer power supply in my Boler Dominique Modifications, Alterations and Updates 0 09-13-2008 06:45 PM
Vintage Trailer Supply Cam A Care and Feeding of Molded Fiberglass Trailers 5 08-02-2007 09:01 PM
Water supply when there's no water supply Dave M Problem Solving -- Owners Helping Owners 18 06-06-2006 10:00 PM
Power Supply Questions Patricia Baxter Modifications, Alterations and Updates 14 05-20-2006 09:45 AM
Power supply Harvey Craft Problem Solving -- Owners Helping Owners 5 04-10-2006 08:51 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
