Plumbing fittings
Hi Peter -
Thanks for the info earlier. Just a few quick questions.
1) What fittings did you use to go from your tank fitting to PEX?
My tank fittings are threaded with a 1/2" barb on the other end to attach braided hose to. If forgoing the hose, I'll need to go from the treaded fitting in the tank to a PEX-type fitting.
2) How did you attach your water line to your city water. I think these are standard (hose fitting on exterior and a big brass female fitting on the inside). Somehow I need to go from this big brass female fitting to the main water supply line on my non-trailer style taps. PEX can get me to the supply lines, but the backside of the city water inlet has me stumped. Do you have a picture of what you've done there?
Cheers,
Mike
