Noisy water pump. - Fiberglass RV
Old 06-24-2008, 11:10 PM   #1
peterh's Avatar
I'm in the process of re-locating my ShurFlo 2088 water pump, and had a question. In its old location (which is in the way of a hatch door I plan to install) our pump made a racket every time we ran it. ShuFlo calls this pump "quiet," but is there a "quieter" yet affordable pump out there or some change in the way I mount the pump that will help make it run a little quieter. Would it help to install an air-gap, for example?
Old 06-24-2008, 11:45 PM   #2
Gina D.'s Avatar
West Coast USA
I have seen muffling kits at camping world, but not really looked into them. I suspect it's a cocoon of soft dampeners.. like wrapping your pump in an insulated, but ventilated blanket. Look near the pumps!
The noise does not bother me, so it's a non issue in my case. I know it drives some folks crazy!
Old 06-25-2008, 12:43 AM   #3
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Peter... When you re:install the pump try putting it on a computer mouse pad!!! Just a thought!!!
Old 06-25-2008, 06:18 AM   #4
BobB's Avatar
A loop of flexible tubing at the outflow might help, especially if you have rigid tubing in your trailer. An accumulator tank connected to the pump outflow can be helpful as well. If all else fails, buy an expensive pump.
Old 06-25-2008, 09:06 AM   #5
Trailer: Fiber Stream
Talking
I am going thru the process of upgrading my pump and periferal equipment.
My main complaint is the intermittant short bursts of pump activity while leaving the pump switch on. My pump sounds like a Semi's Jake Brake when activated.
My existing installation has the pump output connected to the plumbing via plyable yet rigid tubing with the input from the tank connected via a very short bit of flex "hose". The shortness of this hose negates it's flexibility IMHO.
I will end up doing everything BobB suggests.
I am installing Shurflo's "Whisper King" with an Accumulator. The Whisper King installation guide instructs to use a minimum of 1 foot of flex hose on both the input AND output. To get it all to fit in the space provided, I'll have to do just that.
Old 06-25-2008, 06:00 PM   #6
Now why did you have to open up this can of worms? (sore subject for eight years with no end in sight )
I'm on the third pump with no better results, every design produces the same really irritating pounding. Wife: "It doesn't bother me, no really!" "It keeps the dead awake" is my response.
It is now and has been for a few years an Aquatec variable (?) speed unit which behaves just like the previous Shurflo, even the WhisperKing.
I've tried accumulators, have installed the SurFlo silencer tubing, etc. The system gets purged and still refuses to shut up.
If you gents figure this out please let me know. There may be a reward.
Old 06-26-2008, 05:14 AM   #7
BobB's Avatar
First of all, I'm not the guy who opened this can of worms;-) The pump in our Bigfoot TT is an annoying "knocker" but it doesn't drive me crazy. I am going to try to improve the situation though. No perfection, just trying to minimize the noise. My 2 cents:
The old Shurflo 2088 in our Casita was replaced with a Whisper King, which brought the noise level down to acceptable. We also installed a Shurflo accumulator tank (reduces the number of cycles as well as noise). Be sure to look at the specs if you plan to switch pumps. The WK is 2.0 gpm and 30 psi, compared to 2.8 gpm and 45 psi for the 2088. Less flow and less pressure with the WK! I have no experience with other brands or types of water pumps.
The pump in our Bigfoot TT is not installed correctly IMHO. The pump is connected directly to rigid plumbing and noise is transmitted into the bathroom very efficiently. Sounds like a jackhammer. According to the instructions I have, the pump should be installed with at least a foot of flexible high-pressure braided tubing connected to both the inlet and outflow ports (like Per said). One guy writing into the "10 minute tech" series in Trailer Life swears by a 5 foot coil of tubing connected to the outlet port.
These "knocker" pumps must be mounted to something solid, like the floor of the trailer (thick plywood). The mounting screws should be neither too tight nor too loose. I tried the mousepad and it didn't help my situation. If the rubber mounts are in decent shape, I don't see how the mousepad would help.
Sometimes a noisy pump just needs to be replaced due to worn parts. If this is not acceptable to you, try tightening the screws that connect the pump to the pump motor and any other screws that might have worked loose. These pumps can also be re-built or repaired.
If all else fails, try insulating the space where the pump is mounted with some kind of soundproofing material.
I'm thinking of trying one of the Shurflo Smart Sensor pumps in our TT. Anybody have any experience with them?
Old 06-28-2008, 05:42 AM   #8
BobB's Avatar
On closer inspection the rigid tubing in our trailer is only on the inlet side of the pump (Whisper King) and is part of a valve and snorkel (clear tube) arrangement designed to pump antifreeze into the water lines. I have no idea if this was done at the factory or by a previous owner. The question: does this make the pump noise louder?
Apologies to Per for this "can of worms".
Old 06-28-2008, 06:27 AM   #9
james kent's Avatar
Trailer: Boler 1984
It sounds like the floor is acting like a sounding board, increasing the sound just like moving sound in a guitar. Why not mount the pump on a small SEPARATE piece of plywood and then insulate that from the actual floor of the trailer??? Could you then mount the plywood with solid rubber feet?
Old 06-28-2008, 07:10 AM   #10
Roy in TO's Avatar
Has anyone tried mounting their pump using springs? I know I've seen various compressors and motors mounted this way in other applications.
Old 06-28-2008, 08:04 AM   #11
BobB's Avatar
I found some previous threads related to noisy water pumps. Took some time--I'm not good at this! The dates are June 10, 2006 and Nov 15, 2005.
http://www.fiberglassrv.com/board/index.ph...ater+pump+noise
Old 06-28-2008, 02:14 PM   #12
BobB's Avatar
After crawling on my knees and sticking my head in storage compartments for a while I made a slight modification in the inlet water line. The line was too long, which made the flexible part arch up as it passed through a small hole in the cabinet wall ( the photo above does not show this part). The arching made the water line pass diagonally through the hole and it was jammed tight against the cabinet wall and the fiberglass wall of the bathroom. I'm thinking this was amplifying the sound of the pump. Anyway, I shortened the water line, allowing it to relax and fit loosely through the cabinet wall. To put it another way, I removed the valve for the antifreeze. The mouse pad also was removed, as it wasn't improving the situation. It sounds better now--the rapping sound is gone. I hope it lasts.
The Whisper King may be about the quietest pump of this type (for multiple fixtures). I came across some noise ratings and the WK was lowest at 50 db. The Smart Sensor pumps are louder at higher flow rates, although they are just as quiet at lower flow rates. They also cost a lot more. As mentioned earlier in the is thread, there are some very quiet single fixture pumps.
Old 06-29-2008, 09:41 PM   #13
Talking
My main complaint is the intermittant short bursts of pump activity while leaving the pump switch on. [b]My pump sounds like a Semi's Jake Brake when activated.
This is the original water pump.
This is the new pump, in-line filter, and accumulator.
>Silence is Golden!!!<
The flexible hoses:
1. between the tank shut-off valve and the in-line filter and
2. between the pump outlet and the accumulator
are each 18" long.
Old 07-02-2008, 03:04 AM   #14
I have just replaced my water pump and what I did was to NOT attach the pump to the floor it is free floating (it isn't going anywhere). The key to minimizing sound transfer is to keep all connections as flexible as possible. Mounting the pump to the floor increases sound transmission throughout the trailer. I also intend to place a I place a piece of polyurethane foam under the pump, but the pump still won't be secured to the floor. Using this technique, I have found the noise level to be quite low. I also turn the pump switch off when water is not going to be used.
Peter & Carolyn is offline   Reply With Quote
Water Pump Diane H Problem Solving | Owners Helping Owners 10 07-19-2013 07:09 PM
Where to mount Water Pump? efawcett Plumbing | Systems and Fixtures 9 07-13-2007 05:10 PM
water pump problem Jamey Plumbing | Systems and Fixtures 11 03-07-2007 10:32 PM
Noisy water pump Per Walthinsen Plumbing | Systems and Fixtures 15 06-11-2006 11:30 PM
Water pump install Al Stansell Modifications, Alterations and Updates 11 01-18-2006 04:07 PM
