Norcold 3way fridge in my ParkLiner - Page 3 - Fiberglass RV
Old 06-16-2014, 09:16 AM   #41
Night Sailor's Avatar
Connecticut
It seems like a good idea to at least do an inspection. There are screens you can get to keep the bugs out. I have debating using these.
My plan is to add a fan for the summer and see if I can improve the insulation. But this is a low priority as mine is working well.
Old 06-16-2014, 09:26 AM   #42
The Minimalist's Avatar
Louisiana
It's not the vent size per se, but the free air space in the vent. What I did was measure the vents themselves, measuring perpendicular to the vent 'blade' to the adjacent blade, multiplied that times length of the vent opening and then times the number of openings.
There were just not enough openings in the existing bottom vent and they were too close together. On this last it was more a matter of the angle of the blades not providing enough free air space
Actually, before buying a replacement insert for the door, I ran the unit for a couple of days with the lower door open and got excellent results. So, if you think ventilation is the problem, I would try this first.
I then went to Lowe's and Home Depot with ruler and calculator and found a vent that would restrict the vent the least, getting as close as I could to the free air space of the upper vent and still providing adequate protection from weather.
So far so good.
Old 06-16-2014, 07:18 PM   #43
deryk's Avatar
New Jersey
Well I checked the temp when I got home from work at 8:45 pm and it was 40' in the fridge (80' outside temp)so I would say its a Success! So had it on a lower setting on the knob... but I'm happy with the results...guess this is now annual maintenance.
deryk
Old 06-16-2014, 08:02 PM   #44
Connecticut
Glad it worked out for you Deryk.
And Clif, I'll have to study mine some more. I already cleaned it this year. It is working great so far.
Old 06-23-2014, 07:02 AM   #45
deryk's Avatar
New Jersey
Well the new vent is installed. I still need to order a set of keyed alike cam locks...want at least the 2 for the fridge the same. a 3rd for the umbilical cord would be nice too.
I spent several hours bending aluminum to modify/recreate the baffle to direct the heat and exhaust outside. I did have to tuck some fiberglass insulation in there because I now understand why the vent was as small as it was with the galley kinda in the way. But the new hole is larger and I ran the fridge for 48 hours, didn't set off the CO alarm and no more smell of unburned propane, and I got about a 40' difference in outside air to inside fridge at coldest setting....so real happy with that in a near empty fridge. I did contemplate adding a 12 volt fan to help direct the heat out but seems to be working well now.
deryk
fridge, parkliner
3way fridge not working on 12V Rick G Problem Solving | Owners Helping Owners 28 03-31-2010 10:44 AM
Norcold DC0040 12V fridge Angelo F. Classified Archives 5 04-23-2009 08:02 PM
