Originally Posted by D Tharp
I am with you Donna, will let it cool of and let sit upside down for a day. Yes what do I have to loose. But the price of a new one is a lot. I am retired so maybe I will pull every few months and do it again.
Hi,
I suggest you have a look at
Absorption refrigerator - Wikipedia, the free encyclopedia to understand the basics of absorption principle used in LP gas refrigerators.
If it is working fine under 110V, playing shake and bake is useless. The use of reversing the
fridge is mainly to disloge ammonia gas crystals that may obstruct the free circulation of gas in the cooling unit. Presence of ammonia crystals is an indication that the solution of water, ammonia and hydrogen has deteriorated over time or (likely) from overheating (if not leveled properly). No matter how hard you will shake or reverse it, you can't regenerate what's lost. You can only try to use what's left of cooling power.
I found that using a 12 volts computer fan to force vertical air circulation on the outside vents of the
fridge helps to maintain acceptable
fridge operation , but for me, it did not work on very hot days with my old 1977 Dometic 211, so I installed another fridge. There was no use to whip a dead horse in my case. You may be more lucky.
Since Gas operation is the problem, not the cooling unit operation, the first thing to do is to clean up all dust and obstructions, especially between the jet and the pilot. Next, I strongly suggest you replace the jet (accessible when you clean up the pilot burner) and the two stage gas regulator if it is more than 5 years old. They are inexpensive parts, easy to find. The whole cleaning procedure is explained in many service manuals you can find in the document center. Any spider nest or debris that obstructs the
propane jet can cause a misfire and potentially some injuries to anybody who tries to
light the pilot. I had a RM2193 for five years and I must have replaced the jets twice and cleaned up the pilot for spider stuff at least twice every year.
Good luck !
