I have a Prodigy 3 controller installed in our Ford Expedition, which came with the wiring harness installed. Lately, when pulling our Silver
Cloud, the display on the controller will occasionally turn red with the short/no
brakes warning. However, touching the foot brake or using the manual control on the unit will return the display to green and the trailer
brakes engage. I can feel the
brakes engage, so I know they are working. When driving without the trailer, the controller display always stays green.
Other threads on a similar topic have indicated this as a bad ground or wiring short somewhere. However, I would think that a bad wire/ground would cause the brakes to not work at all at times.
Do you think I have a bad controller or what should I check? By the way, this happens without any big bumps, so it wouldn't seem to be a wire bouncing back and forth. Also the 7 pin plug on the trailer has been replaced since this issue first popped a few months ago and I've checked all wheel brake
electrical connections for tightness. Remember, the brakes do work!
Thanks!
