old Coleman Hand Rocker Pump - Fiberglass RV
Old 08-28-2009, 08:20 PM   #1
Trailer: 73 Boler 13 ft
The water pump in our Boler 1300 is misbehaving. Leaks a bit of water out onto the countertop, and requires too many pumps to get even a small amount of water. Feels like a seal is not sealing! I unscrewed the faucet, and see a sealed pump, "Coleman hand rocker Pump, model 2231"
Going to "the City" Tomorrow, and would like to get whatever I need to fix it. Should I try to pry it apart, or would the whole pumps be still available, in Alberta. Thanks!
Peggy is offline   Reply With Quote
Old 08-28-2009, 09:05 PM   #2
Craig B.'s Avatar
Trailer: 1975 13 ft Boler
You should be able to purchase a repair kit from your local rv dealership for about $8, it contains new washers, gaskets and a new ball bearing for the pump. I had just gotten one just a couple of weeks ago. Make sure to lube the plunger gasket with vaseline.
Check the linkage between the rocker arm and plunger, it sometime breaks, and I believe you can also get a kit for that as well. A new pump, might cost you $35 and up.
hope this helps
Just noticed that you are in Central alberta, does that mean you are coming to Red Deer?, if so, I got the parts from Vellner leisure, but they had to order the parts and it took a couple of days to get there.
Craig B. is offline   Reply With Quote
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
Hand pump - lead on a good one? JenPB Plumbing | Systems and Fixtures 9 07-20-2008 09:35 PM
No more hand rocker pump.... kentj Modifications, Alterations and Updates 7 07-18-2008 01:15 AM
1976 Trillium Rocker Water Pump Bill C Problem Solving | Owners Helping Owners 12 04-25-2008 06:48 PM
Hand Pump Water Fixture Brian T Problem Solving | Owners Helping Owners 1 05-28-2007 05:36 AM
