old suburban gravity furnace question - Fiberglass RV
Old 10-22-2017, 05:01 AM   #1
Trailer: Burro, had aliner
model GT 6 3A When the valve beneath the white temperature control knob reacts to the ambient temp, as measure by the thermopile, should the fuel supply to the burner simply shut completely off, until things cool down enough for the thermopile to call for more heat and then the burner gets relit? Or should this valve only reduce or increase the fuel supply with the burner being constantly on, and adjusting itself as required? Thanks
fred wark is offline   Reply With Quote
Old 10-22-2017, 04:16 PM   #2
Trailer: !977 KingsleyGMC, 1968 Bailey Mikado
Nova Scotia
GT-6
Does this help any?
https://www.manualslib.com/manual/10...3a.html#manual
panhead_mike is offline   Reply With Quote
Old 10-22-2017, 04:43 PM   #3
Trailer: Hunter
I believe the main burner shuts down completely when the set temp is reached. The pilot flame should stay lit so that the burner can relight when the temperature falls again. If the pilot flame doesn’t stay lit the cause is most likely that the thermocouple needs to be replaced.
Hope this helps. It’s the way most older gas heating appliances work - before electronic ignition and power vented appliances were developed.
billmccracken is offline   Reply With Quote
Old 10-22-2017, 06:17 PM   #4
thanks mike and bill
Old 10-22-2017, 07:45 PM   #5
Trailer: Trail Cruiser
The pilot light, controlled by the thermocouple, should stay lit all the time to light the burner when necessary. The main burner lights when heat is called for.
furnace
I am looking for a gravity furnace (old style furnace) fred wark Care and Feeding of Molded Fiberglass Trailers 17 03-14-2021 09:13 PM
Old Suburban Furnace Thermostat Question? SteveV Problem Solving | Owners Helping Owners 7 09-09-2015 07:41 PM
exhaust grate for gravity furnace on 1972 Boler Cheryl Lee Care and Feeding of Molded Fiberglass Trailers 1 06-25-2009 02:57 PM
REMOVING a DuoTherm gravity furnace Marv Watson Problem Solving | Owners Helping Owners 5 06-08-2009 05:57 PM
Duo-Therm Gravity Furnace Jake Jacobson Classified Archives 1 11-10-2008 04:13 PM
