Old wallpaper removal - Fiberglass RV
Old 01-14-2020, 04:28 PM   #1
Trailer: Ford Fleetwood
How do I best remove this old wall paper. It's so brittle it doesnt peel anymore. I've tried soaking it with water and it doesn't work.
00pipirose is offline   Reply With Quote
Old 01-14-2020, 05:14 PM   #2
Trailer: Eco
Kansas
you need one of those wallpaper scoring tools from home depot, and a mixture of water and downy fabric softener -- 3-5 parts water per 1 part downy. That takes up any wallpaper better than any commercial product I've seen.
Also, if you don't have a fiberglass camper, there's a pretty good chance someone may yell at you about it soon.
My '71 Eco Restoration Gallery
Baxter is offline   Reply With Quote
Old 01-14-2020, 07:09 PM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Looks to me like paneling used in trailers not wallpaper. Its probably painted on. You may get lucky have it peel off but its not going to be easy. Its usually cheap mahogony plywood under the paint and that is what I am seeing
Old 01-14-2020, 10:42 PM   #4
Trailer: '82 Burro 13'
Northern VA
paint scraper might work well getting that off.
1982 13' Burro
Burro Renovation
Dan-NS27 is offline   Reply With Quote
Old 01-15-2020, 11:47 PM   #5
Trailer: looking
It is not wallpaper. It is a wallpaper like material that was bonded to the plywood at a factory using non-water soluble glue. You can feather out the rouge edges with sandpaper and spackle them. After sanding, prime and paint right over it, or, you can actually hang a more attractive wallpaper. This is what I did in one past RV, do to the ugly "wallpaper" they had used..
ordjen is offline   Reply With Quote
Old 01-16-2020, 09:09 AM   #6
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Besides our boler we have a 1990 19 ft. 5th wheel that had a vinyl wallpaper glued to wood wallboard. Some was coming off so I decided to remove it all and paint. After some trial and error I found a heat gun and it peeled off no problem. I left the joint covers alone as there was no peeling on them. I didn't do any over prep to the walls just painted and it still looks great after 3 seasons.
Good luck with your reno.
Fred
FRED SMAILES is offline   Reply With Quote
Small Leak Caused Wallpaper To Warp dlt123me Problem Solving | Owners Helping Owners 13 01-29-2016 04:13 PM
Wallpaper stick to fiberglass? Leia T Modifications, Alterations and Updates 3 06-29-2011 11:49 AM
Wallpaper Francine P Problem Solving | Owners Helping Owners 6 11-05-2008 02:19 PM
bigfoot wallpaper Ericpa3 Problem Solving | Owners Helping Owners 3 06-19-2007 05:37 PM
bigfoot wallpaper Ericpa3 General Chat 0 01-01-1970 12:00 AM
