One more time on tire upgrade - Fiberglass RV
Old 08-24-2013, 11:46 AM   #1
Trailer: Chez Nous - a 2011 Scamp 16'
I'm guilt-ridden asking this again, and my "search" which lasted 20 minutes didn't give me the answer I need, although I KNOW I read the answer previously
I have a 16' 2011 Scamp, going from 13" to 14" tires. I am quite certain it will not be a problem as many have pointed out their success. A "quick measure" is to use one's fingers to check for spacing while the 13's are still on. Please if someone remembers what I've forgotten -- what is the space that should be above and behind the tire in approximate inches to know for (almost) certain that 14's will fit nicely.
Thanks all.
Sharon
SharonM is offline   Reply With Quote
Old 08-24-2013, 04:01 PM   #2
Brian B-P's Avatar
The largest common 13" ST tire has a width of 185 mm; the smallest common 14" ST tire has a width of 205 mm. The difference of 20 millimetres means that each side needs 10mm (almost 1/2") more clearance than needed for suspension movement and tire distortion while cornering.
The overall radius of these sizes (185/80R13 and 205/75R14) can be similarly compared to determine how much room around the periphery of the tire will be used up by the larger size.
Old 08-24-2013, 06:19 PM   #3
Roy in TO's Avatar
Sharon,
There are charts on the internet that will show you the diameter and width of the various sized and profiled tires. I posted a picture earlier that shows the difference in size of 3 different 13" tires here: Replacing an Axle - leading arm to trailing arm
You will see the problem in trying to get a good answer on 13" vs 14" if there is such a variation in my tires.
Old 08-24-2013, 07:09 PM   #4
Thx Brian, Roy.
Somewhere on here I read that if you can get x number of fingers between tire top and trailer bottom, and x number of fingers between back of tire and something else while the 13's are on, then you know the 14's (like Rabbit/Jack has) will fit fine. I cannot find that blasted post.
Sharon
Old 08-24-2013, 07:46 PM   #5
I'm not going to be much help since I've got 15" tires on my Scamp, but I can tell you that 205s fit (width) in the wheel well. I'm running ST205/75 R15.
Old 08-24-2013, 08:23 PM   #6
Sounds good Donna. I'll get the ST205/75 R14. It'll work, I just know it.
S.
Old 08-24-2013, 08:51 PM   #7
Gilda's Avatar
Trailer: 2011 Scamp 13'
Pardon my ignorance. Why does one put larger tires on their trailer?
The Gleeful Glamper
Gilda (Jill-da)
Old 08-24-2013, 09:05 PM   #8
In my case Gilda: (1) I want easy access to tires while on the road, and 13's are not common, and (2) I want to comfortably carry maximum weight since I'll be fulltiming in my 16' Scamp when the house sells.
Sharon
Old 08-24-2013, 09:42 PM   #9
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Higher load capacity is another reason. Jack knows nothing of Scamp wheel wells, Sharon. Donna's success with 15s suggests that 14s should absolutely work. And you have a practically new trailer which would indicate an axle which isn't decreasing original clearances. No worries.
jack
Scamp Tire wheel upgrade? Nolan Scheid Towing, Hitching, Axles and Running Gear 5 09-18-2007 06:27 PM
» Trailer Showcase
"Ollie"
PhilS
Boler
ostamb
