Ordering new Scamp - Page 2 - Fiberglass RV
Old 09-19-2014, 08:16 AM   #15
Timber Wolf's Avatar
North Florida
The in-the-wall A/C is a nice plus to me on the older Scamps (like mine), would they even do that now? I think it was $179 for a 6,000 BTU replacement window shaker (Home Depot) that does a great job in my 16 footer (and we live in Florida).
Old 09-19-2014, 10:35 AM   #16
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
One roof vent is enough for me. the roof escape hatch also opens. If we need more air we turn on the fan only in the ac. Scamp will not put the ac in the back window or the walls. I would rather have it on the roof out of the way and not taking up space. No heat strip for us a small electric heater from Lowes for 25.00 worked very well. The ac in our first Scamp worked well just would like a low profile model for looks and wind.
Ken
Ken in Pa is offline   Reply With Quote
Old 09-19-2014, 10:40 AM   #17
Actually the "basic 3 speed " only exhausts. The fan provided is reversible as well.
Didn't know that so I guess mine is a little more than the basic. But I was thinking in regards to more speed options - find that in many situations the lowest of the 3 speed models is not low enough.
Old 09-19-2014, 11:51 AM   #18
Oh I had two propane tanks before going with that again. With frig. hot water tank and furnace and no electric at a campsite we may need them.
Ken
Old 09-19-2014, 11:59 AM   #19
North Dakota
Ken, instead of the TV antenna just get the plug for cable hookup. You will have a outside attachment. They just buy an antenna of your own.
Here are some ideas.
http://http://www.homeantenna.org/sq...9oZRoC3t7w_wcB
tv antenna - Free Shipping - DX
I got one of those little black ones with the short post and it seems to work ok. I have to have a TV guy change the plug on the one I got. It didn't have the proper coaxial plug.
I've got one of those flat ones too but haven't tried it yet. I saw one on another FG trailer and the people with it said it worked ok.
Gene Masse is offline   Reply With Quote
Old 09-19-2014, 12:26 PM   #20
Ken
How frequently did you need to refill your propane tanks on your last trailer? I have found that when camping off the grid I can get by a couple of weeks with only one tank of propane even with the fridge on propane full time and running the furnace on and off and hot water tank on.
Old 09-19-2014, 02:28 PM   #21
Carol,
That spare tank is called "ballast". It helps to counteract poor loading technique.
Actually I use my second tank for the little weber Q, and can keep refer and water heater going using the selector valve without closing the active tank.
One time due to poor planning I had to make a run into the nearest town to fill a tank while leaving the critically low one to power the fridge.
We also use a "Little Red Campfire" in areas that allow no wood fires. It sucks the propane!
Russ
Russ
Old 09-19-2014, 02:32 PM   #22
The bigger bed would be my number one factory mod. It is hard to implement after the build due to the wing wall and stove support column locations. Our Scamp is perfect other than that one missing asset.
Russ
Old 09-19-2014, 02:43 PM   #23
Carol,
I wonder if you could add a power resistor to the low setting switch position? Some motors don't like to be run too low. Maybe call Fantastic Fan and ask if that would be an option for you.
Russ
Old 09-19-2014, 04:44 PM   #24
Originally Posted by ruscal View Post
Carol,
Russ
I believe that you can Russ but I can't be bothered.... kind of just adding it to my list of reasons for why I have to have new trailer I have my wishful thinking eye on
BTW I appreciate that you need the extra tank for the fire pit. I have one as well put I use a smaller 10lb tank for it and the portable stove. I have a holder that I put it in so it can ride securely in the back of the truck or the trailer with no fear of it falling over or rolling around. I like having it portable so I am not restricted by the length of hose I have and can place either propane appliances where I want them. Also due to the frequency of how often it needs filling - having a smaller one is easier for me to handle.
Old 09-19-2014, 04:51 PM   #25
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
The basic three speed fan is the reverseable one on Scamps now, just not temperature controlled or remote
Sent from my XT1028 using Fiberglass RV mobile app
Briantb is offline   Reply With Quote
Old 09-20-2014, 06:19 AM   #26
Trailer: Scamp 13'
I would toss the group 24 deep cycle battery and have them put in at least a group 31 AGM. If your going to get serious with solar may even ask if they can fit two six volt batteries up front. You may have a little more room on the tongue of the 16" than I have on the tongue of the 13', the 31 AGM just fits on my tongue. Its always better to have bigger or more batteries. I put my charge controller in the battery box. The closer to the battery you can mount the charge controller the better. A sealed battery dosen't put out the gas as a vented battery, better for the charge controller. Check link below.
Portable Solar Up and Running
Mike-N-Laurie is offline   Reply With Quote
Old 09-20-2014, 06:29 AM   #27
Trailer: Scamp 13'
Check out this antenna by far the best it works where others don't..
Unbelievable RV Antenna
Old 09-20-2014, 06:37 AM   #28
papa-t's Avatar
Glade Valley, North Carolina
Make it your own. What you want. However advice from owners does hold insight from been there done that. Good luck
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Ordering a 16' Scamp, what are the must have options? chuyler1 General Chat 32 03-26-2015 08:01 PM
New 13 Scamp -- ordering lights and electical outlets joeburns Electrical | Charging, Systems, Solar and Generators 5 09-15-2013 12:12 PM
Newbie needs help before ordering my Scamp Hman66 Problem Solving | Owners Helping Owners 68 08-03-2013 08:39 AM
ordering new hinges Ted Problem Solving | Owners Helping Owners 9 10-05-2012 05:16 AM
Ordering parts from Scamp adriemel83 Problem Solving | Owners Helping Owners 5 06-16-2011 05:04 AM
