Ordering new Scamp with Larger 3-way Refrigerator - Fiberglass RV
Old 12-17-2015, 11:59 AM   #1
Trailer: Currently Shopping
Has anyone had this problem? I was prepared to order a brand-new Scamp 16', pretty much with all options. The refrigerators they offer are either a 1.9 Cu ft. 3-way, or a 4.6 Cu ft. 2-way. I wanted to order the trailer with the larger refrigerator, but 3-way. I see no point in a two-way, especially with the way I plan to use this trailer, and the difference in price is usually about $80 - $100.
The salesman first told me that they don't install the larger 3-way because the larger fridge draws too many amps. I pointed out that they draw 15 amps while on 12 Volts DC (according to Dometic's website), and any tow vehicle that could tow this trailer is going to have at least an 80 Amp alternator. Obviously the fact that these 3-way refrigerators are made, and other people actually use them, meant nothing to the people at Scamp.
Then he told me to speak to the owner of the company, who suggested that I buy the 2-way, and operate it on gas while I was driving. This is not only dangerous, but illegal in many states.
I also pointed out that the 3-way and 2-way models are exactly the same size and the only different thing they'd have to do is run a 12-volt line.
After a few phone calls, they finally said flat-out they wouldn't install the 3-way, larger model. The salesman understood that I was ready to order but wasn't going to order unless I could get the refrigerator I wanted.
There's no way I could install it later -the door isn't wide enough.
So, they are loosing an order for a brand new trailer for no good reason. I guess that they have all of the business they want and don't need anymore money?
Bradley is offline   Reply With Quote
Old 12-17-2015, 12:30 PM   #2
I thought I wanted a three-way fridge when preparing to order my Escape. Instead I opted for the larger two-way.
It was pointed out to me that if I left a campsite with a depleted battery ( from running the furnace, etc. ) that when I arrived at the next campsite, I would still have a depleted battery because the vehicle could not supply enough power to run the fridge on 12V and to charge the battery.
If you insist on running your fridge on 12V, you will also have to upgrade the tow wiring to #10 from the normally used #12 just to get enough power to the fridge.
Don't know where you got your information about running the fridge on propane while driving, but it is not correct. It is not dangerous and I doubt you can find a law against it in any state. I know you won't find such a law across Canada.
You will be advised that propane must be shut off before entering tunnels, getting on a ferry and for fueling.
The fridge will stay cold for quite a while when turned off, if you don't open the door, so that's another option.
Old 12-17-2015, 12:56 PM   #3
Trailer: Scamp 16, previously Scamp 13
None
What about level?
Hey, just reading this thread out of general interest, no dog in the fight one way or the other, but I have a confused beginner's question.
How can you run the fridge on propane while traveling? I've heard others discuss this, but I've also understood that the refrigerator needs to be level, with little tolerance, in order to 1) run properly, and 2) not cause permanent damage to the refrigerator.
Seems to me, that travel, with a possible tongue low position or just general travel, particularly in hilly areas would preclude you from running the fridge on propane. What am I missing?
LyleB is offline   Reply With Quote
Old 12-17-2015, 01:11 PM   #4
IllAnnoy
No need for level when moving since the ammonia is kept flowing.
by the motion and the hilly areas and general travel.
Old 12-17-2015, 01:17 PM   #5
IllAnnoy
Surveys say consistently that over 70% of RVs travel with propane on.
Some may say that it is contraindicated, but where exactly is it illegal?
I used my 12V a few times when my trailer was new, but quit using it years ago.
We travel with frozen bottles of water, tea, or other drinks to keep our fridge cold in transit.
Old 12-17-2015, 02:35 PM   #6
None
Thanks Floyd
Thanks, Guess I have to learn more about how these fridges actually work. Taking your word for it, you know a whole lot more about it than I do.
My thoughts were similar for travel, just use it as a big cooler with ice to keep things cold until I get to camp. My trailer battery doesn't charge at all from the tow vehicle, so it would quickly drain the battery.
Old 12-17-2015, 03:54 PM   #7
Most of the newer refrigerators do not DO NOT have a pilot light and are perfectly safe and legal to use when traveling. Fueling and some tunnel restrictions do apply but when I travel my refer is running on propane until I plug into shore power
Old 12-17-2015, 05:12 PM   #8
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
The OP raises some interesting questions, among them:
Replacement fridge installation through the door? I do not think they install the fridge first and then glue the top and bottom of the shell together. Does not make sense.
Running on LP while on the road? Scamp does say in their manuals to turn off the propane when traveling, but very few people follow that recommendation. (I used to when I started, but now I run the fridge on LP when underway.) I believe it is legal, in general.
As an explanation for the benefit of the OP, the small fridge needs less of a heat source to keep the absorption cycle working, and the alternator and the wiring can handle it. With the bigger one, only the 115V AC or propane has the energy density to handle the job. Scamp may have some other good reasons not to provide the large size 3-way.
The Scamp delivery times suggests that they have all the business they can handle. When I visited them two years ago I found out that the company growth is stymied by certain federal regulations (50 employees). Some work they could do actually do inside, they contract to an outside company, down the street. I think they mentioned the trailer frames as an example.
And lastly, the customer is the king, as they say, but even the king is not almighty, as they also say.
Old 12-17-2015, 05:42 PM   #9
IllAnnoy
What difference would a pilot light make when the thing fires up?
I think the biggest concern is a charged line or fitting cracking in transit.
With the tank valve closed that presents no problem.
Old 12-17-2015, 05:50 PM   #10
And, with the safety valves in all new tanks ( that detect sudden increases in flow and shut it down ) is still no problem.
Old 12-17-2015, 06:08 PM   #11
A pilot light is a constant source of ignition. Electronic ignition is only activated when the refrigerator calls for more cooling.
Old 12-17-2015, 06:23 PM   #12
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I would point out that the 6.7 cuft 3-way Dometic I have in my trailer performs quite well on 12v when traveling. For that matter, it stays colder on 12v than it does on propane. The 12v power source when traveling mostly comes from a 150 watt solar panel and the battery stays close to fully charged. I would believe Scamp has no other good reason not to provide the requested 3-way refrigerator other than its "my way or the highway" approach to customer requests. When I ordered my Scamp (no longer owned by me), I asked them to install shelves in the wardrobe closet. They declined.
Old 12-17-2015, 06:41 PM   #13
Paul O.'s Avatar
I wonder if your setup would still work well on a fully overcast day or at dusk or dawn. Any experience under those conditions?
Old 12-17-2015, 07:36 PM   #14
MyronL's Avatar
Trailer: Escape
New Mexico
Solar has never worked well at night for me so if I needed a supplementary power source that's when I would be switching to propane, (or at the very least keep the fridge door shut and eat soup).
MyronL is offline   Reply With Quote
refrigerator, scamp
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
Ordering new Scamp Ken in Pa Problem Solving | Owners Helping Owners 82 01-14-2015 08:38 AM
New 13 Scamp -- ordering lights and electical outlets joeburns Electrical | Charging, Systems, Solar and Generators 5 09-15-2013 12:12 PM
ordering new hinges Ted Problem Solving | Owners Helping Owners 9 10-05-2012 05:16 AM
Ordering parts from Scamp adriemel83 Problem Solving | Owners Helping Owners 5 06-16-2011 05:04 AM
