OT: stuck bolt/nut combo - Fiberglass RV
Old 04-18-2010, 02:07 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
This bolt is stuck because I can't get hold of the nut to stop it from turning, and the plastic it is recessed into to stop it from turning is stripped. Any ideas? There really isn't room to get a hacksaw in. I can turn the bolt but the nut turns, too. Tried WD40.
Old 04-18-2010, 02:15 PM   #2
Pamela S.'s Avatar
Trailer: 1984 Fiber Stream
What about drilling it out from the bolt side?
Pamela S. is offline   Reply With Quote
Old 04-18-2010, 02:29 PM   #3
That might be do-able except it is a swivel wheel and I don't have a vice (and would be afraid of breaking the plastic if I did), so no really good way to hold it while I try to drill, and it is a pretty thick bolt. So what I should say is, someone might be able to do that but I don't think I can.
Old 04-18-2010, 02:51 PM   #4
Chisel and hammer to remove the plastic part? If it's stripped you'll probably replace it anyway??
What part is this from?
Old 04-18-2010, 02:57 PM   #5
It's not stripped, just stuck. And I can't replace the part, or at least I don't know how, its from this.
I'm trying to put in the original sized wheel which is a bit bigger than the pink ones shown. The other wheel was fine. I think I might be able to get the swivel wheel off if I have the wheel out as there is a screw in the base of it- but I can't take the chance of breaking it and then not being able to replace it. I'll have to try with the one that does come loose and see if that's how to remove it- if so I might find a different one to work.
(Not so OT... it has fiberglass parts- the sides- and is a recreational vehicle.. but not molded fiberglass.)
Old 04-18-2010, 03:05 PM   #6
FRANK MOLIS's Avatar
Trailer: 1980 (Circa) 13 ft Scamp (A WORK IN PROGRESS)
Just a thought, you do not have to drill out the entire bolt, just the head of the bolt, then push the rest of it through. Do you have a Dremel or Dremel like tool? A Dremel with a grinding bit should have no problem grinding off the head.
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=44141
FRANK MOLIS is offline   Reply With Quote
Old 04-18-2010, 03:20 PM   #7
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
Drilling and/or grinding will maybe make the bolt hot enough to melt the plastic. Also once the drill catches on the metal bolt, the bolt will probably begin to spin in the hole.
The dremel has an abrasive cut off disc that would probably cut the nut in two. Keeping the plastic cool when doing so is imperative ( use water ). Of course this will also split the end of the bolt, but that can probably be replaced. Also this will leave a slit in the plastic but will probably not be deep enough to matter.
In any case, good luck.
Bud Kennedy is offline   Reply With Quote
Old 04-18-2010, 03:25 PM   #8
The head is recessed, too, so cutting it off isn't possible and I think drilling it out would just cause the nut to spin.
Slicing through everything is a possibility, though I'm afraid of the plastic housing breaking. Maybe I can tape it to try to prevent that. It appears to be heavy molded plastic but is only about 1/4-3/8 inch thick. I took the other wheel off and the swivel housing appears to be riveted on so removing it isn't trivial, it would involve a bunch of stuff.
Old 04-18-2010, 03:25 PM   #9
Liz&Kev's Avatar
Trailer: 75 Trillium 13 ft
You should be able to drill the head of the screw off and push the bolt though (as suggested)
Otherwise, looking at the nut, it looks like you have some room to score the plastic around the nut, and possibly get a pair of needle nose pliers in to put some traction on the nut while you turn the screw.
Liz&Kev is offline   Reply With Quote
Old 04-18-2010, 03:28 PM   #10
This is similar to many trailer issues in that I don't want to do anything that will leave the wheels not working if it goes wrong- they work now, just not as well as I'd like. If I get into something I can't fix, then they won't work at all. I've thought of trying a Dremel cutoff wheel on the bolt from the inside (inside the housing) but that has that issue- if I get partway through and can't cut through, what happens?
The bolt is probably stainless steel. I don't know how that affects hardness.
Old 04-18-2010, 03:30 PM   #11
The needle nose pliers aren't quite what I need... what I need are "chisel-nosed" pliers.. something with a fine, square end! I can get a small screwdriver in one side but it won't hold so some kind of pliers might help. I tried filing down the plastic to get a grip on the nut with pliers but its pretty hard and again, I'm afraid of wrecking the housing.
Old 04-18-2010, 04:51 PM   #12
Joe Z's Avatar
New River AZ
Bobbie:
Tile Nippers (the kind to nip ceramic tile to shape etc) looks like it may work for you and can be purchased in any of the home depot's etc or you can dremel a groove into one side of the nut and then hold it still with a flat head screw driver while you work the other philips head side loose.... just a few backyard idea's.
Hope you get it!
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 04-18-2010, 05:24 PM   #13
james kent's Avatar
Trailer: Boler 1984
Can't you take the whole wheel assembly and bracket off and replace it? Looks like there should be a chair swivel substitute.
Old 04-18-2010, 06:35 PM   #14
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Bobby Mayer... Is there enough room around the nut end of the bolt to insert some popsicle sticks around the hex nut to prevent it from spinning in the hole???
Alf S. North shore of Lake Erie p.s. I hate stuff that's done...not to be undone!!!
Stuck trailer Tom Trostel General Chat 3 06-17-2010 10:43 PM
I am stuck...................... Robin G Problem Solving | Owners Helping Owners 21 05-16-2010 08:31 AM
Shoulda stuck with their TT... Legacy Posts Jokes, Stories & Tall Tales 1 03-01-2003 04:15 PM
Stuck in your head General Chat 0 12-31-1969 07:00 PM
just delayed, not really stuck General Chat 0 12-31-1969 07:00 PM
