Outside light question - Fiberglass RV
Old 10-12-2014, 05:41 PM   #1
Steve_74's Avatar
I have a 79 Boler but the outside door light only works when it is plugged into 110v doesn't work on 12v is this normal?
Thanks Steve
Steve_74 is offline   Reply With Quote
Old 10-12-2014, 06:08 PM   #2
papa-t's Avatar
Glade Valley, North Carolina
Don't know. Maybe someone with a Boler will jump in soon. However every unit I've ever owned the outside light worked on 12v.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 10-12-2014, 07:12 PM   #3
Pam Garlow's Avatar
Trailer: U-Haul 1985
I'm not an expert at all.
But my GF has and old vintage porch light on hers that is 110.
1. Can you check the wiring to the light to see if it is 12v or 110?
2. Why don't you post a photo of it and someone might be able to identify it.
Old 10-13-2014, 05:07 PM   #4
Steve_74's Avatar
Checked it today and it is 12v have to find a wiring diagram and follow it back I guess.
Sent from my SM-T210R using Fiberglass RV mobile app
Old 10-13-2014, 05:28 PM   #5
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Is your battery charged?
mszabo is online now   Reply With Quote
Old 10-13-2014, 05:53 PM   #6
Pam Garlow's Avatar
The converter 'converts' the 110 to 12v and will power the light when the trailer is plugged in, with or without a battery. But if the battery is bad (or not hooked up) the light will only work when the trailer is plugged in.
Old 10-14-2014, 12:11 AM   #7
Steve_74's Avatar
Yes all the lights inside work just the outside one won't work for some reason unless plugged into 110. I will trace the wires and see what I can find although if it's getting 12v when plugged into the wall should have 12v from the battery too. Just thought maybe it was only designed to work off plugin but I couldn't really see why that would be. But if everyone else's works on both I must have something wrong somewhere
Old 10-14-2014, 09:12 AM   #8
A bit of a wild card & low probablitly but have you checked all the fuses on/in your converter?
Old 10-14-2014, 11:31 AM   #9
Trailer: Casita 17 ft DLX SD
The DC output voltage of your converter and your battery are not necessarily at the same level .If the outside fixture has a corroded socket ,lamp or connection ,the higher voltage from the converter may be sufficient to overcome the added resistance and light the lamp .
Old 10-14-2014, 03:12 PM   #10
Steve_74's Avatar
That was the first thing i did was clean the connections and put a new bulb in. But i havent checked any fuses yet
Sent from my SGH-I747M using Fiberglass RV mobile app
light
Anyone Have Outside String Light Ideas? barryra General Chat 25 07-15-2012 08:00 PM
Installed Smart Light 1000 Motion Activated LED porch light Fran L Modifications, Alterations and Updates 2 02-01-2012 02:05 PM
Replacing Outside light on Boler Ann B Modifications, Alterations and Updates 20 10-07-2006 02:14 PM
outside light switch won't move Karalyn Problem Solving | Owners Helping Owners 13 05-31-2006 09:14 AM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
