Outside Outlet not Working on Casita - Fiberglass RV
Old 05-07-2010, 12:40 PM   #1
Trailer: 2007 Casita Spirit Deluxe
Hi My Friends!
Think I got the dumping issue figured out for the most part so now on to other problems.
The outside outlet on my Casita SD does not work. Could it be a blown fuse? Where are the fuses? What should I do?
Thanks, thanks, and thanks!
joy
joy mccalla is offline   Reply With Quote
Old 05-07-2010, 12:45 PM   #2
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Were you pluged into shore power?
Old 05-07-2010, 12:53 PM   #3
pjanits's Avatar
Trailer: 17 ft 1986 Burro
If it's outside it should be a GFI Ground fault interrupt type. Look and see if the little reset button needs resetting. It should be between the two outlets. OR it may be linked to a GFI outlet inside that also doesn't work and that one needs the reset
Old 05-07-2010, 05:17 PM   #4
shane n's Avatar
Yes, push the button and it will work, happed to me last week camping. My cushions fit tight agaist the outlet on my Liberty and I think pushed it.
shane n is offline   Reply With Quote
Old 05-10-2010, 07:31 AM   #5
Thanks. Will try your suggestions.
joy
casita
Outside outlet Placement joelh Modifications, Alterations and Updates 6 07-13-2010 03:40 AM
Adding an Outlet to Cabinets - HOW? GordM Problem Solving | Owners Helping Owners 18 06-16-2010 06:39 PM
12 volt outlet RonMayo Modifications, Alterations and Updates 9 08-21-2008 06:45 PM
Adding 12 v outlet Legacy Posts Problem Solving | Owners Helping Owners 3 08-19-2003 08:06 AM
