05-14-2012, 06:48 AM
Trailer: Trillium 1972
Packing wheel bearings?
Called my local Jack Williams to see if they can pack the wheel bearings, and they responded without looking at it they don't know. I don't know enough about it- other than I see on this forum it is suggested it be done every 3 years. My Fiberstream was in storage for at least 10- and Ive only owed it a year now. Would I know if the bearings had to be packed by the way the trailer pulls? I can say Ive pulled the trailer cross country at pretty decent speeds w no problem.
05-14-2012, 06:59 AM
Trailer: 1983 13 ft Scamp
I repack every spring.
05-14-2012, 08:54 AM
You need to have the bearings repacked now and again every few years. The only way to tell if there is an issue is to measure the temperature of the wheel hub. Some touch it with their hand and others use a little portable non-contact thermometer.
Non-Contact Pocket Thermometer
In any case you are way past due.
05-14-2012, 09:07 AM
Ok- i have to admit, i don't even know what wheel bearings are. I should have mentioned i did get brand new tires and rims a few months ago- I dont know if wheel bearings are a part of this, or if they are a part on the trailer itself. ?
05-14-2012, 10:34 AM
The wheel bearings are in the center of the thing that the wheel rim bolts to. The bearings would not have been touched by replacing the tires and rims.
Any competent mechanic can repack the bearings for you - i.e. don't get ripped off at an expensive RV dealer..
05-14-2012, 11:15 AM
How to here repack a wheel bearing video etrailertv - YouTube
Wheel bearing
05-14-2012, 12:02 PM
Call around to local mechanics and get a price for doing the work.
05-14-2012, 12:13 PM
The non contact thermometer that Thomas mentioned is more than well worth the $12.99 price.
05-14-2012, 02:51 PM
Cindy conventional RV wisdom seems to be that the bearing should be inspected, repack and seals replaced once per year or every 10,000 miles, whichever comes first.
Suspect the reason they indicated that they cant say if they can or can not be repacked is they need to look at the condition - they may need replacing not just repacking.
05-14-2012, 03:01 PM
Thanks everyone!- the trailer bearings get looked at tomorrow, I will update on the outcome.
05-14-2012, 03:02 PM
Trailer: 2007 Casita
I was also told to do it every 10,000 miles. Since you haven't done it since purchase, I would just for the sake of it. Won't hurt anything to do it now.
05-15-2012, 08:31 AM
Diagnosis: I need new wheel bearibgs and brakes for the trailer! Soooo...i have to take it to a RV dealer. Hopefully I can get an appoint before my camping trip this weekend!
05-15-2012, 09:31 AM
Sorry to hear that but its not really a big surprise based on the age of your trailer. Dont be surprised if they tell you that you need a whole new brake assembly and not just new brake pads.
You dont need to take it to a big RV dealer - they normally charge way to much. There are often small shops around that are not dealers but who do maintenance & cheaper than the big dealers. There is a fellow in my area who use to work for a big RV dealer that was located here - they moved from the area but he set up shop on his own doing repairs and maintenance only - its a very small but a busy place! :-)
05-15-2012, 10:02 AM
Does anyone know how dangeroys this is to continue to pull?! We had planned to go camping this wkend about2 hr away.
05-15-2012, 10:30 AM
Well Cyndi - having a toasted wheel bearing could result in you loosing a wheel and could lead to a not so good ending of your trip. Add to that the fact your brakes need replacing is not IMHO a good combo - the end of the day the choose is yours but keep in mind if it all goes bad you may not be the only one that's impacted.
05-15-2012, 04:01 PM
Wheel bearing failure can be very serious. I'd take it to a local trailer fabricator / repair shop and have new brake assemblies and bearings installed. They have all the parts and know how without the high prices of an RV dealer.
05-15-2012, 06:50 PM
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Just had the wheel bearings in my 13' Scamp repacked yesterday for $60 at the local auto repair shop where they replaced my tires last fall for $180. Boy those little tires are a wee bit spendy. There aren't any brakes on my trailer. I feel better now that it's all done, tho. Can relax a bit when I'm driving down the highway...Well, at least until I have to back into the campsite.
He did say the bearings actually looked ok, but figured he'd repack anyway since he had the tires off.
My neighbor said he'd show me how to do the repacking next time. 10,000 miles might take me a while.
Lil M.
Updates and improvements to LilScamper here
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
05-15-2012, 09:17 PM
Well good news- i opted not to take it to this larger RV place - whomnin the past has charged me ridiculous amts of $ for wgat?! Im still trying to figure it out!---I actually found a small family run RV repair shop and campground also in the Poconos, PA. The mechanic was my age, knew of my family and our business, etc. Etc...anyway, he really took the time to explain everything to me. Told me exactly what I needed. He said alot of these RV repair places are only trained to install new parts, costing RV owners so much unnecessary $; that its becoming harder to find repair people skilled on older trailers. Well, end of story: my bearings will be replaced, brakes, and installation of that brake controller thingy inside my TV- and be ready for my trip to Mighty High Fest this weekend!
05-15-2012, 09:20 PM
Actually Lil you are best not to wait until 10,000 miles - its one year or 10,000 which ever come first. Always for your on comfort best to have them down at the start of each year.
05-15-2012, 09:55 PM
Hi Carol, Would you share the name of this little place in our neighbourhood. you can pm me if you'd like.
Cheers,
Mark
