Old 08-02-2012, 08:30 AM   #1
vics454's Avatar
Trailer: 1973 Boler
paint
I'm the new kid on the block. I am picking up our 73 boler this weekend. The inside is liveable, but the outside has to be painted. I was reading on marine paint and I was wondering if I could get some more info.
Vic.
vics454 is offline   Reply With Quote
Old 08-02-2012, 08:52 AM   #2
Trailer: 1973 Hunter Compact II, 1983 Starcraft 14 p/u, 1994 Lil' Bigfoot, 2013 Coleman 17' Hybrid (Kids use)
I just finished painting my Hunter Compact-II with Interlux Briteside and it came out beautiful. You will need to learn about the Roll & Tip method of application, and don't try painting without at least two people, one to roll the other to do the tipping.
The Interlux site (and many others) have info on the application technique.
On the plus side, it gives an excellent finish.
On the minus side: a) It's expensive, b) color selection is limited, c) It's expensive, d) It has to dry a minimum of 24 hours between coats (it will take at least two) e) It's expensive, f) You should use the special undercoat before applying color coats, and g) Did I mention that the paint is a little on the expensive side, but worth the price?
BTW: Preparation is the key to a good job, the actual pant application is fairly quick and easy
Old 08-02-2012, 09:20 AM   #3
vics454's Avatar
Trailer: 1973 Boler
Thanks for the reply Bob. When you say expensive, how much a quart?
Old 08-02-2012, 09:37 AM   #4
I bought Interlux Briteside at a local Marine supply for about $35/qt for undercoat and $110/gallon for color. I used 2 qts of undercoat and over 3 quarts of color.
Old 08-02-2012, 11:49 AM   #5
slots881's Avatar
Trailer: 1972 Boler
I used Interlux Brightside marine paint also.
Here's a link to my paint job if you want to take a look:
My 72 Boler Reno
slots881 is offline   Reply With Quote
Old 08-02-2012, 09:54 PM   #6
What makes you think it needs to be painted? You know these trailers came from the factory with a gel coat finish... NOT paint. Right? We can help bring back the shine, if that's what you're looking for. Once someone has "fixed" holes with bondo and/or epoxy... well, that's a different story.
If you're only looking for "shine" save a bunch of bucks to spend on fuel to get yourself to camp or pay for a site, just let us know what you REALLY need.
BTW Vic, to FiberglassRV
Double Yolk
1988 16' Scamp Deluxe
Old 08-02-2012, 10:05 PM   #7
Don't Paint?
What, and miss out on the chance to have a trailer that actually has a touch of color???
The chances of an intact gelcoat on a 39 year old trailer that has been exposed to the elements might be slim to none. And, in the case of my 39 y.o. Hunter, it had already been painted over almost 30 years ago.
Beside that, painting is fun, it's doing the preparation that sox.....
Old 08-02-2012, 10:07 PM   #8
I'm certainly not opposed to paint on eggs Bob, but without knowing more, Vic may think the only way to get a shine... is paint. And we know that's not true.
Double Yolk
Old 08-03-2012, 10:53 AM   #9
DannyH's Avatar
Trailer: 1976 Scamp 13 ft "Siesta"
Vic, if you need to paint, another paint to consider is Petit. It's similar to interlux, is a marine paint and I found good reviews on the shin lasting. It's a one-coat paint and they also have a good primmer. I agree with bob that the preparation sux, but my trailer had little gel coat left and I had to do fiberglass work, so it was no question that I needed paint. If I had a trailer and was just concerned about the shine, I would try the polyglow or similar treatment first. Send some pictures of your trailer when you get it.
Dan H
Just for fun Photo Website - http://www.flickr.com/photos/dan_hottenroth/
DannyH is offline   Reply With Quote
Old 08-03-2012, 02:23 PM   #10
No paint--floor finish
ID:	49593Click image for larger version
ID:	49592Click image for larger version
My 1975 Trillium. Just washed with Vim, rinsed and 5 coats of Zep WET LOOK FLOOR FINISHED. Shines like a million bucks !
Ron
RRJR is offline   Reply With Quote
Old 08-03-2012, 07:56 PM   #11
Trailer: 1977 Boler
Hey Vic -
I used Brightside Interlux marine paint about two months ago for our '77 Boler. We needed only two coats to cover up an ugly goldish brown colour. I did white on top and dark blue on the bottom. I did NOT prep with primer or undercoat. I simply sanded it really well and then sanded again between coats.
Using the roll and tip method, if you feel like you're putting lots of paint on, it turns out really well - the only time I ran into trouble on the coats is at the beginning where I was a bit tentative with the paint and used less than I should have. And it didn't take long to do at all, but I would encourage doing it in a larger space than a tandem garage...
The high gloss shine was totally worth the extra bucks. For the two coats, we used about 1.25 quarts for the bottom and then 1.75 quarts for the top and door. And it cost anywhere from $37 to $40 here in Vancouver.
The worst part about doing it yourself is the first time you get a nick in it, you want to cry...!
Good luck!
s.
Sue and Graham is offline   Reply With Quote
Old 08-03-2012, 09:10 PM   #12
Deb & Chuck's Avatar
Trailer: Fiberglass trailers
I have a 1973 Boler the paint was good a little dull. I poli-glowed the whole trailer it shines like new. I painted a Compact Jr. with Topside marine paint it costs $35.00 a gallon. I did not use a undercoat. It came out really nice and no one helped me.
Chuck
Deb & Chuck
www.fiberglasstraveltrailersrv.com
Deb & Chuck is offline   Reply With Quote
Old 08-03-2012, 09:49 PM   #13
Roy in TO's Avatar
I found an interesting article that seems to give a good explanation. I've been thinking of painting the top and door, polishing the gelcoat on the bottom half.
Topside Painting - Rolling and Tipping
I'd be interested in hearing from those that have painted if they agree with what is being said in the article.
Especially this comment:
"Fiberglass gel coat is not an ideal surface for paint. It is so slick and has such low porosity that paint has a hard time adhering. A primer coat that chemically softens the gel coat and bonds to it should be used prior to applying the first finish coat of paint. Special fiberglass primers are made just for this purpose."
Old 08-04-2012, 07:46 AM   #14
As mentioned, I just finished painting my Hunter with Brightside and I agree with everything in the article. The marine supply house that I bought my paint at was adament about using the special primer. I was told that they have seen unprimed applications bubble and/or start peeling within 3 months of application. If you're going to pay $35 a quart for paint, do it right the first time.
paint
Insulation - to paint or not to paint? Trillium.Stella Problem Solving -- Owners Helping Owners 23 09-04-2012 10:46 PM
Which paint is best? Nicole D Care and Feeding of Molded Fiberglass Trailers 5 07-16-2011 11:59 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Paint George A Care and Feeding of Molded Fiberglass Trailers 2 08-25-2008 09:19 AM
To paint or not to paint andrew ferguson Care and Feeding of Molded Fiberglass Trailers 8 08-14-2007 07:02 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
