Paint and calk "elephant hide" 1977 13 ft scamp - Fiberglass RV
Old 10-21-2017, 11:06 AM   #1
Trailer: Currently Shopping
I am remodeling a 1977 13 ft scamp and the original wall "elephant hide" is sagging, needs paint, and needs to have the seams filled in. Any information on products to use or techniques to complete this project?
Jiggs is offline   Reply With Quote
Old 10-21-2017, 11:34 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Jiggs, although I have not personally done what you are about to do, there are past threads explaining the process. Basically you should reglue the sagging ensilite, thoroughly clean it, use a paintable latex calk to fill in the seams. You dampen a rag or paper towel wadded up to gently dab at the calk prior to it fully drying to try to match the texture of the elephant hide. Paint with a good latex paint. If you donít want to go this route, you can still purchase new seam tape.
Keep us posted and take pictures of the entire process.
Good luck.
Dave&Paula
Old 10-22-2017, 03:46 PM   #3
Virginia
Jiggs the seam tape from scamp is guaranteed to stick only to the hair on your arms & yank it out. The 3M spray adhesive that’s recommended to add on makes an awful mess with overspray & leaves your hands tacky for days. It will hold the tape up just long enough for you to think you accomplished something then promptly fall down & attach to the upholstery. Save yourself the money & aggravation, do the caulk. I wish I had!!
sharon_b is online now   Reply With Quote
Old 10-22-2017, 04:06 PM   #4
What to use to glue that stuff? I tried the 3M adhesive spray and it didn't work well.
jeroen is offline   Reply With Quote
Old 10-22-2017, 07:10 PM   #5
Iowa
Steve cleaned the skin with Simple green. then he caulked with a silicone caulk. I tried it and made a mess. He tried to use tape on both sides and it worked great.
ladylavender is offline   Reply With Quote
Old 10-26-2017, 11:34 AM   #6
Buggeee's Avatar
Trailer: Playpac
OH
Here's a section from my build thread on this.
I followed it up with two coats of high quality, mildew resistant, exterior gloss acrylic latex paint tinted to my color preference. Love it.
Originally Posted by Buggeee View Post
Back inside we go...
...I used an instagrab type construction adhesive to ...re-lay the elephant hide over it. This is what they use for things like tub-surrounds and stuff like that. Its like liquid nails in the sense that is handled like caulk and stays flexible - but it grabs immediately. I used it wherever the elephant hide had come loose from the fiberglass walls... this stuff works GREAT, and its real fast and real easy. Just squirt it around on the wall or the hide and smooth the hide back on with your hands. Done. I used a squeegee like for auto body filler to smooth the adhesive along the seams as a filler, rather than the tape, which had come off.
Then two good coats of Bulseye 123 Plus primer, which is good for smooth surfaces, and here's how things stood on the walls.
Buggeee is offline   Reply With Quote
Old 10-26-2017, 12:02 PM   #7
For my 78 Boler I made a cut in the middle of the sagging parts. I then spread " no more nails" with a small trowel. It's been three years and still holding. I also spread a small amount over the incision to approximate the two sides.
Dennis Hannaburg is offline   Reply With Quote
Old 10-26-2017, 12:09 PM   #8
Lydia W's Avatar
Trailer: 1975 Scamp 13 Ft.
Jiggs... I tried putting up new seam tape in my 1977 13 foot Scamp and was extremely frustrated. I'd get the entire camper taped only to find it sagging or completely off the next morning. Spoke with Scamp about it, did everything they told me to do, but still found the tape wouldn't stick properly. Finally gave up and used paintable calk. It turned out perfect! I haven't painted the elephant skin or calk - didn't need to - and 5 years later it still looks great. I may re-calk in a few places, but otherwise it's holding up better than I expected.
Lydia W is offline   Reply With Quote
Old 10-26-2017, 12:13 PM   #9
amazin
Some of you guys and your solutions are amazing!
bob
paint, scamp
Rat fur, Elephant hide, OR? neauone Modifications, Alterations and Updates 27 01-23-2017 08:25 AM
Elephant hide help! Tonnie Problem Solving | Owners Helping Owners 16 01-13-2017 09:53 AM
Elephant Hide neauone Modifications, Alterations and Updates 7 06-08-2013 08:23 AM
How to reglue the elephant hide? David Tilston Problem Solving | Owners Helping Owners 6 08-07-2012 08:35 PM
Scamp Elephant Hide John Perry Problem Solving | Owners Helping Owners 3 10-22-2006 10:15 PM
