Paint or dye? Flap or vent? - Fiberglass RV
Old 04-30-2003, 10:22 AM   #1
OK all of you Rustoleum vinyl painters, does it eventually flake? I want to spruce up the interior walls and ceiling of my Scamp (has the vinyl-covered foam stuff - ensolite?) but have heard dyeing may be better. Any comments?
Also, the former owner put a wall-mount (actually, closet-mount) AC next to the door in my 13 footer. The new repacement AC I bought is not as deep and therefore leaves a large hole (19 1/2 " wide by 13" tall) in the side of the trailer. Should I consider a closable fiberglass flap - and can you get this material for making such from Scamp? Or would a vent suffice?
So many questions - so much fun!
Old 04-30-2003, 11:31 AM   #2
spray vinyl etc
I sprayed mine with vinyl just last spring - OK so far, but not too long of a test. Although, I know I bump up against the stuff on a regular basis... Does that count as abuse?
AC - I assume the old AC unit stuck clear out the side of the trailer??? Anyway - if it's where I think it is, that's a fairly common place to mount an AC unit. MOST of them however don't stick out the side. Vent panels are usually installed to let the unit breath.
mkw
paint, painting
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
What paint to use Jayson Wall Problem Solving | Owners Helping Owners 6 06-20-2007 05:04 PM
new paint job Sandra Lair Modifications, Alterations and Updates 7 06-01-2007 07:35 AM
outside paint job Legacy Posts Problem Solving | Owners Helping Owners 11 04-04-2003 07:44 AM
