Painting - Fiberglass RV
Old 01-02-2006, 07:20 PM   #1
Jollean's Avatar
Send a message via ICQ to Jollean Send a message via MSN to Jollean
Hi Everyone!
Hope 2006 brings you all many fun fiberglass adventures.
I repainted the Boler walls last spring and this year I would like to rip off the cupboards and paint the frames for the shelves and sink. They are metal though, so I am hoping to avoid anything that may flake off. Any suggestions?
Thanks,
Jollean
Jollean is offline   Reply With Quote
Old 01-02-2006, 09:27 PM   #2
Dan Quinn's Avatar
you will need a good epoxy paint..the last timei did a sink (metal)i bought some that was made for tubs and such get it a one of the larger home stores i got mine at menards.it needs to be cleaned real good scuffed with a emory cloth and then paint in a well ventilated room open all windows and turn on a fan sucking out..it is not hard and looks great....
Dan Quinn is offline   Reply With Quote
Old 01-02-2006, 09:39 PM   #3
Lizbeth's Avatar
Jollean, what parts are metal? On all Bolers that I have seen the cupboard frames are fiberglass.
Old 01-02-2006, 09:44 PM   #4
Years ago I painted an old clawfoot bathtub and like Dan mentioned it was painted with Epoxy. It stood up well to daily baths, but nothing harder than skin ever touched the surface. Based on that experience, I'm not sure I'd want to paint a sink in a trailer tho. Is the sink in your Boler enamel or stainless steel or something else?
We may be able to give you better alternatives than paint
Old 01-02-2006, 10:12 PM   #5
Jollean's Avatar
Donna your so smart! I re-checked the cupboards and counter and they are likely fiberglass. They look a lot like plastic. Ok same question I guess, what is best used to paint these?
Old 01-02-2006, 10:16 PM   #6
Dan Quinn's Avatar
i would still use a high grade epoxy paint.
Old 01-02-2006, 10:19 PM   #7
Well I can't take credit... that was Lizbeth, but you can use any paint for fiberglass. Check the labels. Someone mentioned Melamine(?) in an earlier topic. Just make sure the surface is very clean and grease free and scuff the surface lightly. Apply a thin coat and if necessary apply a second.
I think someone has even used Rustoleum, but I can't be positively certain of that.
Old 01-02-2006, 10:21 PM   #8
Lizbeth's Avatar
It wasn't Donna, it was me.
I sanded mine to remove the shine and painted them with Zinsser Perma White paint. http://www.zinsser.com/product_detail.asp?ProductID=35
It's what I used to paint the whole interior, so far so good. I'll try to find a picture to post.
Old 01-02-2006, 10:27 PM   #9
Lizbeth's Avatar
Here is a link to my post about my Boler's new kitchen. It shows a bit of the paint and further down what the kitchen looked like before the redo.
http://www.fiberglassrv.com/board/in...howtopic=13173
Old 01-02-2006, 10:29 PM   #10
Jackie is also redoing her trailer, check out Remodeling the Kitchen, Nice and Fresh Jackie mentions using white acrylic paint, to lighten it up, and painted the outside of the cabinets with a spray enamel.
Now you have several choices.
Old 01-02-2006, 10:44 PM   #11
Jollean's Avatar
Ooops Lizbeth very sorry I am a little all over the map. Thank you to all three of you. Milda, Fred and Nancy!
Ok a few more questions then. I used Zinsser on the inside of the Boler for the walls and although it was good and sticky it is not very shiny or smooth. Did you brush it on? If so do you have paint strokes at all? Anything on top of it?
Also that is one fine kitchen you put together. What did you paint the back splash with to look so nice? Do you have anymore pictures of your unit?
Thanks!
Old 01-02-2006, 11:00 PM   #12
Lizbeth's Avatar
I used small napped rollers on the walls and on the cabinets I used a foam roller. The walls took two coats and the cabinets took three, the sponge roller applied the paint very thin. The result is a fairly smooth finish with a bit of "stippling". I didn't use anything over it.
The backsplash was painted with latex paint from Home Depot to match the countertop....Bear Brand I think.
I've got tons of pictures, they were posted but with the site hack the post went bye-bye. It's far from finished but in the next couple days I'll try to repost some.
Old 01-02-2006, 11:51 PM   #13
Jollean's Avatar
Thanks Lizbeth, look forward to seeing those.
painting JIM DUNNE Problem Solving | Owners Helping Owners 8 06-13-2009 10:59 PM
painting- how much do i need Janet G Modifications, Alterations and Updates 4 05-03-2009 06:51 AM
Painting my 5er? Christi V. Problem Solving | Owners Helping Owners 0 07-04-2008 02:38 PM
Painting the outside gerry gregory Care and Feeding of Molded Fiberglass Trailers 5 07-10-2006 05:03 PM
Painting the Egg Dan Quinn General Chat 8 01-03-2006 09:05 PM
