Painting 81 13ft Scamp questions - Fiberglass RV
Old 04-01-2012, 06:48 AM   #1
Trailer: 13' Scamp "pending"
Im starting to look for someone to paint our old Scamp, is there a certain process that has to be done when painting fiberglass? so i just dont let some idiot talk me into painting it the wrong way and wasting money, all im used to is the automotive type prep, can just a two stage process like primer,paint and clearcoat work? just looking for some advice, thanks
81scamp is offline   Reply With Quote
Old 04-01-2012, 10:23 AM   #2
Most body shops have probably painted fiberglass cars. You would want to remove all the windows, vents and trim so the paint edges wouldn't fray later on. I'd bet you would have to get all traces of silicone caulk completly gone too. Nothing sticks to that stuff. You could research PPG's site or call them for info on compatible primers and top coats. They may be able to give you info on what sanding grit to use on the gelcoat too. Painting is expensive, but you could make your egg look way better than new. The trailer is a blank canvas!
Russ
Old 04-01-2012, 10:37 AM   #3
jen b's Avatar
Trailer: 1980 13 ft. burro
I have just gone through this process with my Burro. My dad and I worked with a local body shop that was willing to do the painting. We did all the prep ourselves, including the primer. It was a ton of work, especially the endless hours of sanding, but made the actual painting process more affordable ($1500 for the body shop, which included painting the inside with a single-stage type paint, and a paint-plus-clearcoat metallic on the outside). It was just finished yesterday.
jen b is offline   Reply With Quote
Old 04-01-2012, 10:52 AM   #4
When prepping the fiberglass Is done
I use a slick sand primer from Evercoat
It is meant to go over fiberglass and will hide any spider cracks that fiberglass tends to get
Than after a quick sand with 400 grit
I apply utech single stage paint
Comes in any Color you could dream of
and is priced
Very well
It's strong like plastics and shines forever
Siris is offline   Reply With Quote
painting, scamp
Axle Upgrade Questions - '81 Scamp 13ft Jon W Towing, Hitching, Axles and Running Gear 6 08-05-2010 07:53 PM
Scamp 13ft Deluxe Questions Raz General Chat 12 02-18-2010 10:32 AM
interior painting questions Naomi P Care and Feeding of Molded Fiberglass Trailers 8 02-14-2009 10:38 PM
Questions on the 16' Scamp William Lee Care and Feeding of Molded Fiberglass Trailers 1 05-02-2008 07:55 PM
Questions about painting exterior Chris J Problem Solving | Owners Helping Owners 3 02-23-2008 10:29 PM
