Painting/decorating the outside - Fiberglass RV
Old 01-13-2007, 07:45 PM   #1
Trailer: 1976 Boler 13 ft
I plan on doing a design on the outside of my trailer and would also like to refresh the outside with a polish. It's been suggested to use mcguires color restorer to bring up the shine. I'm also assuming it will need sanding where I want to paint my design. Should I spot sand or do the color restorer first? Do I need to sand before applying the color restorer? Is it like a buffing? I'm worried the color restorer may affect adhesion, which will be difficult to begin with.Thanks
cyndi H is offline   Reply With Quote
Old 01-13-2007, 08:01 PM   #2
I'm thinking you're right, paint doesn't stick to wax. But, maybe someone has done exactly what you're talking about and they'll speak up with a definitive answer.
Old 01-13-2007, 09:09 PM   #3
Chester Taje's Avatar
I put a stripe around my unit and i sanded where stripe was placed.Worked good for me.Its now been on over two years.No paint fade or wear spots.
Old 01-14-2007, 04:24 AM   #4
Charlie C's Avatar
Trailer: 2000 Casita 17 ft Spirit Deluxe ('Millenium Eggloo')
When applying decals to areas that are typically waxed, alcohol (the standard rubbing type, don't waste the good stuff) is recomended as a surface preparation for good adhesion. I would think that a good wipe down with the rubbing alcohol in the intended area should be plenty, then just re-wax everything after the paint has set up nicely.
Fiberglass gel-coats are somewhat porous compared to a lot of painted surfaces, so when free of wax / grease / oil, I would think that paint should stick reasonably well, especially to a more aged surface.
Charlie C is offline   Reply With Quote
paint, painting
Perris Pacer Decorating Vickie B. Modifications, Alterations and Updates 56 08-09-2010 10:19 PM
interior decorating Rarebird Problem Solving | Owners Helping Owners 11 07-03-2007 11:54 AM
Need decorating suggestions... Bobbie Mayer Problem Solving | Owners Helping Owners 16 06-19-2007 12:34 PM
Fluffy Tail Christmas Decorating Donna D. Jokes, Stories & Tall Tales 10 12-18-2005 08:46 PM
Xmas Decorating on the Egg Gina D. General Chat 13 12-12-2005 04:47 PM
» Virginia Campgrounds
