Painting gun - Fiberglass RV
Old 01-06-2014, 10:34 AM   #1
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
Painting gun
Anyone used an electric sprayer to paint their egg?
Any brand/model you suggest?
tartosuc is offline   Reply With Quote
Old 01-06-2014, 11:16 AM   #2
Yuk, you are looking for a lot of extra work, mess, clean-up expense etc. .
Google "Roll and Tip" painting technique. It's pretty much the standard of the fiberglass boating industry.
It works perfect and much easier and less messy than spraying.
I've done two RV's that way and it's the way to go. It will look like a spray job when finished. Paint selection is also critical, come back and ask about that as well.
Old 01-08-2014, 03:36 PM   #3
arlon's Avatar
Trailer: 2002 Casita Bunk Delux
I built a 17 boat (glass/wood) and used the "roll and tip" approach. With a few coats and some light sanding, looked like factory gelcoat.
2002 Casita 17' Bunk Model Delux (replaced 28' 5th wheel)
2003 Dodge/Cummins quad cab (daily driver/tow vehicle of choice)
2005 AWD Astro Van/camper (my solo camper)
2006 Xterra MT (for sale)
arlon is offline   Reply With Quote
Old 01-16-2014, 01:56 AM   #4
peterh's Avatar
I'll vote with Bob & Arlon: Unless you're looking for a really professional paint job, the Roll & Tip method is probably your best bet. That's what we used for the base color coat on our Surfside project, 3-4 coats (depending on where you look) and it came out really well using Rustoleum's Topside marine paint. Not quite spray-paint quality, but darn close. You don't need the spray equipment, respirator, or a spray booth to use it. Use an HVLP sprayer and the spray mist gets everywhere . . . plan on most of the things in your shop space turning your paint color, including your lungs, if you don't protect them with a full respirator designed for paint sprayers.
As for what sprayer to use, you really need a high-volume, low-pressure (HVLP) spray gun and compressor to apply modern finishes. My setup includes a 6 gallon tank compressor and HVLP spray gun, both from Harbor Freight. HF's HVLP spray guns are a variable commodity, though: some last, others don't, but if you look online you can find instructions on how to disassemble their guns and replace the seals that tend to break down, clog the spray head, and mess up your paint job.
Old 01-16-2014, 08:06 AM   #5
I can't entirely agree with Peter about the possible quality of Roll & Tip painting.
After I did my first ever Roll & Tip paint job on my Hunter Compact-II, I happened to pull it into the service area at one of the largest independent RV dealerships in SoCal and the first question I got asked by the Service Manager was "Nice job, who sprayed it for you". And almost every one who sees it asks the same question.
IMHO: The paint should get more credit than my humble attempts at application. Interlux Briteside went on like "Buttah" and looks great.
I also did a Roll & Tip paint job, using Rustoleum Marine Paint (Not the same stuff as Rustoleum paint at Home Depot etc.) on a 35 y.o. Starcraft pop-up I restored for my son and the results, albeit on a more textured surface, look 100% spray painted.....
Pics of both can be seen here: Robert Miller's (advocateone)'s Library | Photobucket
But, success all depends on doing these three critical steps right: preparation, preparation and preparation.
Good Luck
paint, painting
Painting with Spray Gun - Help Needed Please slavandheather Problem Solving | Owners Helping Owners 13 08-31-2013 01:19 PM
Rivet Gun Rarebird General Chat 7 04-15-2010 09:34 PM
Making Curtains with Glue Gun Pamela S. Problem Solving | Owners Helping Owners 3 04-14-2010 07:38 PM
Rivet gun question DannyH Problem Solving | Owners Helping Owners 12 01-11-2010 05:09 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
