Painting inside of Boler - Fiberglass RV
Old 03-22-2015, 09:04 AM   #1
Trailer: 1974 Boler
Manitoba
Hi there!
Just purchased a 1974 Boler. Needs some TLC.
Was wondering if you can paint the spongy
insulation on interior walls and if so what
kind of paint does anyone recommend??? Also
what kind of sealer strips do I use???
Thanks for any help!!
rainey is offline   Reply With Quote
Old 03-22-2015, 09:09 AM   #2
Ian G.'s Avatar
Originally Posted by rainey View Post
Hi there!
Welcome to the forum Lorraine and Yes you can repaint the interior
The important part of a good interior paint job is both preparation and using the right products. The link below contains the details
Cleaning & Decorating the Interior
Old 03-22-2015, 09:20 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Anything can be painted,, but please clean it up and reconsider.
The surface painted will look the same as the surface unpainted but clean in a year or so. The painted surface won't stand up to cleaning as well as the original surface.
We use our boler several months a year so it is cleaned often and past experience with paint proves to me not to paint it.
Fred
FRED SMAILES is offline   Reply With Quote
Old 03-24-2015, 08:47 PM   #4
Trailer: 1974 boler
Hi there, I also just purchased a 1974 boler and I am definitely going to paint the ensolite...it's a sickly silly putty pink right now. Looks like most recommend zinsser 123 primer and good prep. Is there a similar link for painting the interior fiberglass? It needs to be much more durable than the spongy walls. Not sure if I should use zinsser primer for that too? I've seen some have used marine paint but apparently it cannot be repainted in future. Thanks
Thanks
Dinab is offline   Reply With Quote
Old 03-24-2015, 10:00 PM   #5
Kootenay's of BC
I don't mean to doubt the quality of your paint job in the boler.
My concern is cleaning the paint after,,, say cooking on the stove,
using the boler say in the fall not cleaning it and coming out to in the spring and finding mold over most of the ceiling.
You have possibly one of the nicest bolers around, but really how many nights a year do you spend in it?
We spends months at a time in ours, in it right now since Feb 1. and almost a year in it out of the last 4.
The factory surface is superior in about every way to the painted surface
and with use the painted surface won't look good down the road.
To those considering painting their interior,,, please reconsider.
Fred
Old 03-25-2015, 05:08 AM   #6
Trailer: 1974 Boler
Manitoba
I have read that people have used melamine paint on the fiberglass and acrylic enamel paint for the ensolite. Looks like we are in the same boat Dina...you'll probably get started before me...it snowed again in Winnipeg the other day!!! You have any pictures of your pink interior?? Was it painted once before or was that the original color??
Old 03-25-2015, 06:00 AM   #7
Ian G.'s Avatar
Fred
Hi Fred
We actually average 5-6 weeks annually using the Boler, like most we do the majority of our cooking outside but we do cook inside, we also bake in the oven. We scrub the interior walls at least twice a year, the paint is holding up very well, no issues, pealing, cracking or mold.
I totally agree with you that if you don't need to paint DON'T, the vinyl surface is far more durable than any paint will be, I even mention this in my instructions on painting the interior. In our case the vinyl was stained and discolored, no cleaning product would bring it back to white (and trust me I tried everything).
In our case painting was the only solution other than removing the ensolite and replacing with another product.
Old 03-25-2015, 08:06 AM   #8
Kootenay's of BC
hey Ian, thanks for the clarification, painting should be a last resort.
WOW 5-6 weeks congrats on that!
I see you have another trailer so I kinda assumed your boler was more of a show piece,, which it is!
Later
Fred
Old 03-26-2015, 12:36 PM   #9
Trailer: 1974 Boler
Manitoba
Any suggestions on how to tell if ensolite is saturated with water and needs to be riped out. Some of my seals around windows and inside are shôt and have had a very small amout of water since it snowed again.
Thank you
Old 03-26-2015, 01:05 PM   #10
Ian G.'s Avatar
The ensolite is a closed cell foam and will not absorb water so you have nothing to fear, any moisture will only be on the surface.
I don't advise you rip it out as it is a ton of work and expense to replace it.
Old 03-26-2015, 03:39 PM   #11
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
I'm going to semi-disagree with you on this - while the ensolite is a closed cell foam and it won't absorb any water itself, there is NOTHING to prevent water from pooling "behind" the ensolite against the fiberglass walls, depending on how well (or not so well) it was originally glued in place. Eventually it may open up enough "pockets" between the ensolite and walls that it drains all the way to the floor, but I can absolutely guarantee you that any moisture won't be limited to just the "surface" - it can definitely be quite wet behind the ensolite, and the completely slimy/moldy and disgusting approximately 3x3 piece I removed from my scamp last summer is evidence of that.
If you suspect that you have water *behind* your ensolite, I suggest carefully peeling back as much of the ensolite as you need to, fixing the leak, allowing everything to dry out fully, and then gluing it back in place with spray adhesive - I did something similar when I repaired my front bunk support that had separated from the shell (not due to leaking, the tabbing had just popped clean off on one end) and you really can't even tell that I remove the ensolite at all - and I peeled back enough that I could get in there and properly prep the fiberglass for repair without risking damage to the nearby ensolite).
sarahspins is offline   Reply With Quote
Old 03-26-2015, 04:11 PM   #12
Ian G.'s Avatar
My statement is true that ensolite will not absorb water.
Old 03-26-2015, 04:32 PM   #13
sarahspins's Avatar
Yes, but you also stated that the water would only be on the surface - which is not true.
Old 03-26-2015, 08:19 PM   #14
Trailer: 1974 boler
Interior painting
hi Rainey
Sorry, my boler is in the garage and photos don't turn out so well with poor lighting. Plus, not sure how to post photos yet. No snow here but lots of rain! I am in the process of gutting it...I plan on doing a complete Reno. I have recruited my retired dad and brother into a "family project". They are currently welding a new frame for me (my dad is a welder and both are super handy). My boler interior was actually repainted pink at some point and luckily it is sticking well and not peeling...just ugly. My ensolite is in pretty good condition but I have read that sometimes water pools behind it and causes it to bubble because it can't seep through it. I agree that replacing it would be a nightmare. It's going to be a while before I get down to painting...lots of prep to do first. Half the fun of owning a boler is renovating it, the other half will be camping in it
boler, paint, painting
Painting/Coating the inside of Burro compartments Thomas A Problem Solving | Owners Helping Owners 4 07-07-2013 08:58 AM
Trim-Loc on Burro/painting inside reydenna Care and Feeding of Molded Fiberglass Trailers 1 04-19-2011 09:50 PM
Prepping inside fiberglass for painting ursulap Problem Solving | Owners Helping Owners 6 05-20-2010 10:05 PM
Painting Inside Trillium Dan N Problem Solving | Owners Helping Owners 1 08-16-2009 05:23 PM
Boler Inside Electrical/charger/inverter kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 09:11 PM
