Painting my Playpac - Fiberglass RV
Old 04-23-2007, 10:59 AM   #1
Trailer: Play Pac
Hello all, I recently purchased a Playpac. This is my first trailer, and I am new to this site...so I have lots of questions. My first being that I am wanting to paint the vinyl walls inside the trailer. It was painted over once, put it was cracked and peeling, so I have stripped most of it off. I am wondering if anyone out there has done this before and what is best to use. Thank you...this is a great site.
Liza S. is offline   Reply With Quote
Old 04-23-2007, 02:04 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
FIRSTLY and most importantly, Liza, let me welcome you to our cozy l'il group of Glass Egg Lovers
As with ALL good paintjobs the best results ALWAYS start with the best prerperation job. I think I'd try to get as much of the old paint off as you can, then make sure all areas you want to paint have been 'scuffed', usually just a light sanding, just enough to remove any sheen that might be showing. Following that wipe all surfaces down with a good cleanser (mainly to remove any possible fingermarks which might leave a slight 'film' to which the paint may not stick as well to. You might even consider a coat of primer paint (specially usefull to ease the transition between color changes from the old to new paint.
If you are still unsure what to do, why not come out to your local Glass Egg Meet on the May long weekend at Bigfoot Campgroung in Harrison?? Many of us there have painted inside and outside our 'egg shells' LOL!!!!
Old 04-24-2007, 01:57 AM   #3
Trailer: Play Pac
Thanks Doug, I will be starting on it tomorrow, so I will let you know how it goes...Thanks for the invite sounds like fun, I will try to make it.
Old 04-24-2007, 05:08 AM   #4
Welcome to FiberglasssRV Liza..we're glad you found us!
Interior paint...oh yeah, a number of topics address this issue. Click on either of these links for more reading:
Painting the innerds...,
Interior Paint discussion here...1978 Surfside
I searched for +Interior +paint and found four pages of topics!
Old 04-24-2007, 05:50 AM   #5
Mike Watters's Avatar
Trailer: TrailManor (Gone to the Darkside)
Although I had a PlayPac at one time - the interior was already gone when I bought it so I never had to deal with it. As such - I glued carpeting onto the walls. Kind of a pain to do - but nice and cushy to lean against.
What I used in a Boler (different material than a PlayPac has, but still a vinyl-like face) was a special vinyl paint (made for car dashboards). Worked quite well on the rough ensollite, but when I've used it on smooth surfaces, it always flaked off.
I've also played around a little with the new "Plastic Paint". Made a haloween costume using the stuff. Very impressive and clearly will NOT flake off. Kind of on the thin side though and would definately need a primer coat first to cover the pattern on the original walls. Both the vinyl and plastic paints come in spray cans.
Most everybody else however has used assorted brush-on or roll--on paints.
Mike
Mike Watters is offline   Reply With Quote
paint, painting
Still looking for the VIN # on a Playpac James McKnight Problem Solving | Owners Helping Owners 8 06-17-2011 06:48 PM
Playpac VIN# location? James McKnight Care and Feeding of Molded Fiberglass Trailers 2 05-24-2010 08:23 PM
PlayPac Kevin K Referrals: Molded Fiberglass Trailers 0 05-08-2010 06:23 AM
I just bought a .... Playpac! Chris Bradford General Chat 12 09-15-2009 07:42 PM
