Parking in a tight spot - Fiberglass RV
Old 10-17-2007, 03:55 PM   #1
Trailer: 17 ft Casita
I believe somewhere I read about using a winch to pull a egg type trailer back into a tight parking space? Does anyone know of this or give me some idea on how it would work. I only have 5in clearance on each side if I manage to get it in straight. A real pain.
BOB & JACKIE
Bob Radenbaugh is offline   Reply With Quote
Old 10-17-2007, 04:07 PM   #2
How big is the trailer? In your profile, under your name... it says RV Type: None...
If the trailer is going to be parked on asphalt/concrete or hard packed dirt, I'd recommend a tongue dolly.
I can move my 16' Scamp Deluxe around on asphalt with one.... and I'm not that strong. I can back the trailer through the gate with about 6" on each side, but need to jockey it around a bit once it's unhooked.
An inexpensive, easy solution...
Harbor Freight Trailer Dolly
Old 10-17-2007, 04:08 PM   #3
If you've got a reasonably flat and firm surface this should work pretty good. Because I have a very sharp (90) right at the end of my driveway I use one to put the trailer away and pull it out so I can hook up.
Old 10-17-2007, 06:38 PM   #4
Chester Taje's Avatar
The one person i remember who winched in their RV was one of our Japanese members. He had to winch it into a tight parking area at his home in Japan. The trailer was a Casita. I would think a small 12 volt winch could do the job if area is flat.
Old 10-18-2007, 09:23 AM   #5
Suz
Suz's Avatar
How's this for tight?
We have since taken those trees down and added a cover. It's still pretty close getting it in because of the angle of entry. A winch would not have worked in this case.
We used the dolly like in the above posted link for quite a while. It worked fine as long as there were two of us (one as a spotter). Since I camp alone, I wanted to be able to get the trailer in and out by myself (like when hubby is gone) so I got a behemoth of a power mover (12V) on ebay. That sucker is ugly and old, but it's got the weight that I need to be able to stop and hold it in mid-move to make sure my angles are correct.
Suz is offline   Reply With Quote
Old 10-20-2007, 06:51 PM   #6
Pete Dumbleton's Avatar
A useful alternative is to mount a front hitch ball (It doesn't have to be monster-sturdy). It may also be of aid at a campground someday.
Old 10-20-2007, 10:03 PM   #7
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
For you western canadians looking for a towing dolly I found a 600# one at a store called Bianca Amor's "Liquidation Supercentre" for $49.99, which is still a lot more that the Harbor Freight one, but a lot cheaper than the Princess Auto version at $64.99
Lainey is offline   Reply With Quote
Old 10-22-2007, 08:45 AM   #8
Thanks to all of you who answered my request. I have went out of town for a few days and am now the proud owner of a 1999 17ft. Casita. Do you all think it will work if I mount a 12Volt winch at the back of my parking area and then use one of the harbor freight type dollys to maneuver while pulling the Casita back into a very tight gravel surface spot. I have about a 5 inch clearance on each side. I was not sure if the tow dolly would be strong enough and able to move on the gravel? What power of winch should I get, would a 2500 LB pull be more than enough or would I have to go to a big 7,000 lb one like they mount on the front of jeeps? I really have no experience with this, so all help appreciated.
BOB & JACKIE
Old 10-22-2007, 09:40 AM   #9
Chris Z's Avatar
Trailer: 16 Scamp, 17 Casita, 21Bigfoot now
http://www.casitaclub.com/forums/index.php...;highlite=winch
Look at this. I think the first one is what you are looking for.
Chris Z is offline   Reply With Quote
Old 10-22-2007, 09:55 AM   #10
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Bob,
I've found that a riding lawn mower (if you have one, and depending on the size and the terrain) will also work quite nicely. I have an 18 hp Kubot garden tractor with a hydraulic 3pt hitch right now (oh boy what a difference!), but I have moved many trailers around for years with an 11 hp Honda riding mower.
Roger
Old 10-22-2007, 10:04 AM   #11
Thanks so much !!!! The winch and dolly, EXACTLY WHAT I HAVE BEEN LOOKING FOR!!!!
Only difference is that I think I will mount the winch on a steel pole cemented in the ground and then hook the cable to the trailer frame, and pull it back that way....
BOB & JACKIE
Old 10-23-2007, 04:30 PM   #12
Brian B-P's Avatar
Dolly sources:
I bought mine at Princess Auto, but at a sale price.
Since then, I've seen them Costco, at a very reasonable price.
Riding Lawn Mowers
There's no chance I'm putting my Boler's 300 lb of tongue weight on my lawn tractor. It's a 20 hp John Deere, but it is not intended to take that kind of load. A garden tractor like Roger's is a very different thing, and a small egg with half the tongue weight of mine might be more reasonable even with a lawn tractor.
Having moved a 24' deck flatbed trailer with a small farm tractor, I agree that a tractor can be very maneouverable, and it's great to be able to see exactly what's going on in the hitch area.
Old 10-23-2007, 05:02 PM   #13
How about one of these Electric Motorized Dolly?
I used to move my utility trailer and boat trailer using my old-style Gravely mower (two-wheel, 8 hp) with a ball mounted on the sulky.
Old 10-23-2007, 06:31 PM   #14
I've been forced to use a PowerCaster motorized dolly somewhat like that. The driveway has a couple of inclines which puts traction to the test. The amount and proportion of tongue weight on your trailer will determine just how much traction you will get.
If the driveway is wet I lose some traction to the point that I have to lean into it to get up the incline. If I added 100-200 lbs of weight on the tongue, as in a filled water can, I would have all the traction needed.
If I win the lottery I may install a moving system by Truma or a similar U.S. system. No traction problems whatsoever and you can move the trailer from 25 feet away by using a remote control, and with pinpoint accuracy to boot.
Parking in a tight spot. Pat C Care and Feeding of Molded Fiberglass Trailers 5 08-20-2008 11:22 AM
How tight should this be? Kevin K Problem Solving | Owners Helping Owners 6 05-31-2008 09:39 AM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 07:30 AM
Tight Quarters in your 13' Egg? Frederick L. Simson General Chat 8 01-17-2007 07:44 PM
» Virginia Campgrounds
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
