This may be applicable to other trailers, but is specifically for my
Parkliner.
What is this type of connector called? The dc pair is split using this connector (2) and then one pair goes to
light and other goes to 12 v receptacle. I need to buy 2 of them.
I'd like to put a lock on the inside of the screen door. I know it won't keep anyone out, but it may cause them to make enough noise to wake me up. Has anyone installed a lock they recommend?
The latch that keeps the screen door closed needs adjusting. The one that keeps the door open works fine, but the one that keeps it closed doesn't spring all the way closed. Has anyone figured out how to adjust it? (I've already had Chandler adjust it once).
